Overheating
PostPosted: Sun Jul 11, 2010 12:05 pm    Post subject: Reply with quote
Keith D wrote:
Jim,
I'm not nit picking, but Austin Sevens most definitely DO have oil pumps!
Keith
Sorry Keith, I was trying to make a point and obviously my recall failed me. As old as I am, pre-Second World War cars were still (almost all) before I was born and though I worked on a few survivors in the Nineteen Fifties the memories are a bit hazy!
Jim (at least, I THINK that's my name).
HMK
PostPosted: Mon Jul 12, 2010 4:42 am    Post subject: Reply with quote
Yes, I was just going to say that I was sure that Austin sevens had oil pumps. I'm not a "seven" expert, but the last time I travelled in one was about 2 years ago & about 50 miles & it definitely had an oil pressure gauge. I seem to think the reading was quite low - something like no more than 10 psi, could have been even less at times, but didn't seem to bother it.
As for semi or synthetic oil in 'older' engines - it is VERY good for the metal bits of the engine, but it is NOT good for the seals. I made the mistake of using a semi synthetic oil in an older engine & a once dry engine started weeping from every seal. I got rid of the semi syn & filled with proper mineral oil & within a few weeks, all the leaks from seals had stopped & the engine was nice & dry again.
PostPosted: Mon Jul 12, 2010 9:18 am    Post subject: Reply with quote
I don't think synth actually damages seals. It just escapes more readily. It's good at getting everywhere.
PostPosted: Tue Jul 13, 2010 4:06 pm    Post subject: Reply with quote
Cork and rope seals have no hope of keeping 10/40 semi where it should be so for some pre-war cars I am afraid its treakle (straight 50 or 40). Some seals can be replaced with modern ones or treat them as total loss oil systems. Wink
1936 Morris 8 Series 1
1973 MGB roadster
1977 MG Midget 1500
Dax Rush
Salopian
PostPosted: Wed Jul 14, 2010 8:33 am    Post subject: Reply with quote
I've used Valvoline 10w50 fully synthetic (acquired some old stock at a very good price) in my 1928 Sunbeam 20.9hp with complete success. No leaks smooth running and best of all much reduced difference between hot/cold pressure.
It never uses much oil anyway and did not with the synthetic.
One consideration with such as the Sunbeam and my Alvis 12/50 are the oil pump bevel drive gears - such as a straight 50 grade oil will give silly high oil pressure cold and these gears can fail.
An oil thread can go on for ever and we all have our favourites but I use modern multigrades and have done for years without problem.
Anyway to get on topic sounds like blocked rad to me but hope its something simple!
Jonathan Butler
PostPosted: Thu Jul 15, 2010 10:18 am    Post subject: Reply with quote
Just for interest. Multigrades are made of base oil then a long chain polymer is added, eg Paratone viscosity index improver. ( I asked someone else, I'm not that smart). Wink
1973 MGB roadster
1977 MG Midget 1500
Dax Rush
traction39
PostPosted: Thu Jul 15, 2010 10:55 am    Post subject: Reply with quote
What ratio of anti-freeze to water are you using? Too much anti-freeze will lower the boiling point...maybe with higher engine loads the radiator cannot cope?
Just a thought..it was a cold winter!
PostPosted: Sun Jul 18, 2010 12:59 pm    Post subject: Reply with quote
I use 50/50 anti freeze/ deionised water, seems to work fine and I replace it every 2 years. I was also doing some prep work on the B and found the thermostat housing casting quite corroded inside and the outlet was resticted to about 50%, I thought " um, this could make it overheat". And I thought of you.
1973 MGB roadster
1977 MG Midget 1500
Dax Rush
PostPosted: Sun Jul 18, 2010 2:35 pm    Post subject: Reply with quote
50:50 seemed to protect to -55 acording to my hydrometer, any more and it starts to go down again (or up if you like!)
traction39
PostPosted: Sun Jul 18, 2010 5:52 pm    Post subject: Reply with quote
-55 degrees! Guess Suffolk gets pretty cold in winter!!!
victor 101
PostPosted: Sun Jul 18, 2010 6:04 pm    Post subject: Reply with quote
Like Nic I use a 50/50 with deionised water, not so much for the low temp but as engine protection.
WLC4EVA
PostPosted: Sun Jul 18, 2010 6:19 pm    Post subject: Reply with quote
Mike (MV Peters) asked "Does anyone have any hands-on experience of synthetic oils in vintage motors? "
Yes Mike.
What do you wish to know?
Kind Regards, WLC
PostPosted: Sun Jul 18, 2010 6:22 pm    Post subject: Reply with quote
I wouldn't even try! hehe
WLC4EVA
PostPosted: Mon Jul 19, 2010 4:55 pm    Post subject: Reply with quote
Why wouldn't you even try it Buzzy?
Kind Regards, WLC
PostPosted: Tue Jul 20, 2010 10:06 am    Post subject: Reply with quote
Buzzy just loves replacing bearings.
Buzzy, you are using a computer. Shocked
1973 MGB roadster
1977 MG Midget 1500
Dax Rush
Page 2 of 3
