ka
Posted: Fri Feb 13, 2015 7:47 am Post subject: |
I have seen a Fog light used as a reversing light, just a single one providing a wide low spread of light, may need a relay to give the switch an easier life, but worth a thought. As an option, I have also seen combined rear fog, and reversing lights as an after-market item. _________________ KA
Better three than four. |
Posted: Fri Feb 13, 2015 9:06 am Post subject: |
You need something from James Bond or Thunderbirds like the number plate light swivelling round to light your way.  |
vitesse
Posted: Fri Feb 13, 2015 4:26 pm Post subject: |
ka wrote: | I have seen a Fog light used as a reversing light, just a single one providing a wide low spread of light, may need a relay to give the switch an easier life, but worth a thought. As an option, I have also seen combined rear fog, and reversing lights as an after-market item. |
I have seen this one online that wouldn't look too bad mounted below the bumper in the middle. It looks like good quality but nearly £40!!!!!!!!
http://www.holden.co.uk/displayproduct.asp?pCode=010.451
I was wondering if I could modify a rear light lens and remove the reflector at the bottom and replace it with a clear lens? |
Posted: Fri Feb 13, 2015 10:49 pm Post subject: |
Very nice looking lamp.
This was just posted to Facebook. You could adapt this elegant idea.
fog light by peterthompson, on Flickr |
vitesse
Posted: Sat Feb 14, 2015 5:31 pm Post subject: |
Crumbs why are three people sitting on a settee smiling about with a 500 engine lid with a dodgy rear light on their laps.
Perhaps they are buying a car in instalments? |
ka
Posted: Sun Feb 15, 2015 8:01 am Post subject: |
They are studying for the follow-up to Slumdog Millionaire, with a specialisation in Fiat Engine covers, and rare fog lights as aftermarket items. I am also concerned where the arms and hands are belonging to the middle man, and that may account for the smiles on the other two faces! _________________ KA
vitesse
Posted: Wed Feb 18, 2015 7:08 pm Post subject: |
ka wrote: | They are studying for the follow-up to Slumdog Millionaire, with a specialisation in Fiat Engine covers, and rare fog lights as aftermarket items. I am also concerned where the arms and hands are belonging to the middle man, and that may account for the smiles on the other two faces! |
Oh I didn't notice his lack of hands but that smirk does look suspicious. |
vitesse
Posted: Wed Feb 25, 2015 9:28 pm Post subject: |
As it was a bit warmer today I ventured out to the garage to do some work on the engine and gearbox.
I fitted a new clutch and release bearing last time I was working on it and now it was simply a case of joining the engine and gearbox back together, refit the starter motor and set the tappets gap.
I was hoping to spray the tinwork that surrounds the engine bay but needed to apply some Kurust to some bits and it can't be sprayed for 3 hours after application.
Once the tinwork has been sprayed I can carry on with the rebuild and I am waiting for some bits from Germany, including a rebuild kit for the carb.
Posted: Wed Feb 25, 2015 10:13 pm Post subject: r hav |
It's funny how conventional the setup looks, bolted together without the cowling. I would never have thought of doing the cowling afterwards.
It looks very smart. |
vitesse
Posted: Fri Feb 27, 2015 9:57 pm Post subject: |
I got around to painting the cowling today, it needs another couple of coats but I have to wait 24 hours before I can apply them. Then I will probably stick it in the oven for a bit to cure it off nicely, the paint can handle 120°.
Went for a nice gloss finish as per the original, really nice finish but I did manage to spray myself in the face at one point try to get the trigger handle off the top of an almost empty tin.
Posted: Fri Feb 27, 2015 10:12 pm Post subject: |
Shiny shiny. Look like they're made out of treacle.  |
vitesse
Posted: Sat Feb 28, 2015 6:16 pm Post subject: |
Yes that's what I was using Kev, trying to pull the handle off was when I sprayed myself in the face.
They are really good, makes spraying with cans so much easier. I got it free when I ordered some cans on the Internet.
I must say I do think I have ever seen paint this glossy before. |
JC T ONE
Posted: Sat Mar 07, 2015 3:48 am Post subject: |
Nice progress
Engine is looking good.
Jens Christian _________________ http://www.eurods.eu/wp/index.html |
vitesse
Posted: Sun Mar 08, 2015 9:39 pm Post subject: |
Thanks Jens it's all going back together now, so hopefully by next week I should be able to bench test it.
