lowering a midget
Finch661
PostPosted: Sat Mar 19, 2011 9:14 pm    Post subject: lowering a midget Reply with quote
i have completely rebuilt my midget 1500 suspension, replaced all the bushes with poly ones. anyway i decided to lower the car as i have removed the rubber bumpers. I changed the springs to 1275 ones, but now the suspension sits a lot higher than before. i have rolled the car back and forth, but it hasnt settled.
have i done something wrong
1985 Mini Mayfare (1275)
1976 Mg Midget 1500
PostPosted: Sat Mar 19, 2011 9:58 pm    Post subject: Reply with quote
Did you tighten the suspension bolts while the wheels were dangling? That's a NO NO. You have to tighten when the car is sitting on it's wheels.
Art
Finch661
PostPosted: Sat Mar 19, 2011 10:35 pm    Post subject: Reply with quote
ah yeah i did, when reassembling the various bits i tightened them all up. didnt think that that would be a problem. would it be the wishbone bolts causing this problem then, opposed to the shock absorber?
1976 Mg Midget 1500
PostPosted: Sat Mar 19, 2011 11:18 pm    Post subject: Reply with quote
Nothing to do with ride height, but is there a lower kingpin grease nipple wanting some attention there, under the claggy muck?
PostPosted: Sat Mar 19, 2011 11:23 pm    Post subject: Reply with quote
Finch,
Any bolt that goes thru' a bushing should be re-adjusted.
Art
Finch661
PostPosted: Sat Mar 19, 2011 11:24 pm    Post subject: Reply with quote
aye, i need to clean up the grease nipples. one thing at a time lol
1976 Mg Midget 1500
Finch661
PostPosted: Sun Mar 20, 2011 1:23 am    Post subject: Reply with quote
cheers 47jag. so i should loosen the nuts when the cars on its wheels and allow the car to resettle, then tighten up the nuts?
1976 Mg Midget 1500
PostPosted: Sun Mar 20, 2011 1:37 am    Post subject: Reply with quote
Yes. Give a bounce or two to flex the suspension, then tighten.
Art
Finch661
PostPosted: Sun Mar 20, 2011 8:32 am    Post subject: Reply with quote
cheers, will try that today and let you know how i got on!
1976 Mg Midget 1500
Finch661
PostPosted: Sun Mar 20, 2011 5:16 pm    Post subject: Reply with quote
had a go at re settling the bushes/suspension, but still no joy. Someone has pointed out to me that the suspension spring may not be seating properly, and in pic the spring looks arced out towards the wheel
1976 Mg Midget 1500
victor 101
PostPosted: Sun Mar 20, 2011 6:37 pm    Post subject: Reply with quote
Its normal for the spring to arc as the top and bottom seats are not parallel, find a small coil spring and press between finger and thumb and it will do the same if not squeezed straight.
PostPosted: Sun Mar 20, 2011 6:58 pm    Post subject: Reply with quote
Yes, that spring does look a little odd.
If it's easy enough to take the spring out again, you might compare the static height of it against the old spring, along with the wire diameter. This might give you some idea as to whether it's the correct spring or not. There's also a green smudge of paint on the lower coil - this is often an indication of the spring rate - one of the Special Tuning manuals will tell you what this means.
Sorry I don't have those reference materials (any more!).
2002 MINI Cooper 'S'
Finch661
PostPosted: Sun Mar 20, 2011 8:15 pm    Post subject: Reply with quote
they are brand new springs, i compared them with the old ones and they are the same height. after looking at my pic, they dont look right. i
haha i thought that the green mark was green primer Smile Will google it and see if i can find some info about it. It should be a 1275 standard spring
If anyone has any pics of their suspension that would be great
another pic
1976 Mg Midget 1500
