changing earth polarity
MartinC
PostPosted: Fri Apr 15, 2011 5:35 pm    Post subject: changing earth polarity Reply with quote
I may need to change from positive earth to negative.
There's no fancy electrics to bother about.
Can someone remind me of the procedure to follow with the dynamo please?
Although I did once connect a car battery backwards and converted the dynamo just from starting the engine!
1937 Standard Flying Twelve
1942 Bedford OYD
1947 Cadillac Fleetwood Sixty-Special
1954 Hillman Minx
1956 Austin A30
1957 Vauxhall Victor Super
1960 Car Cruiser Carousel caravan
1962 Car Cruiser Carissima caravan
PostPosted: Fri Apr 15, 2011 6:33 pm    Post subject: Reply with quote
Hi Martin,
Just disconnect the F and D terminals on the dynamo, connect them together and briefly touch them onto the positive battery terminal and it should start up when you reconnect them as before.
If you have an SU fuel pump do check that there isn't a spark arresting diode connected across the contacts (Remove the Bakelite cover to see it.)
PostPosted: Fri Apr 15, 2011 8:05 pm    Post subject: Reply with quote
Coil and ammeter need doing as well and possibly clock. Loads on this in SEARCH
Rover P2
Morris Mini Traveller Mk2
MartinC
PostPosted: Fri Apr 15, 2011 9:50 pm    Post subject: Reply with quote
Thanks Peter,
As I said Phil, there's no electrics to bother about. I'll do the coil of course (although they do work fine connected in reverse), there's no clock, no ammeter, no SU pump.
1942 Bedford OYD
1954 Hillman Minx
1956 Austin A30
PostPosted: Fri Apr 15, 2011 11:07 pm    Post subject: Reply with quote
Depending on terminal type these may have to be replaced or swapped over
Rover P2
PostPosted: Sat Apr 16, 2011 4:40 pm    Post subject: Reply with quote
Don't know what car we are talking about, but if it is late enough to have any permanent magnet motors such as heater or wiper they will run backwards. Wipers will still work, but the parking cam in the motor will be running contrary to its design profile and will probably fail eventually.
Wound field motors will work as before.
