finandarch
captinbash
Posted: Tue May 31, 2011 8:33 pm Post subject: |
Hello, It looks the same as the one that was in my first Viking and that was gas only, with the same three controls, the main one the thermostat then the button you have to push and hold to light and then the knurled knob that you spin to strike the flint. Are there any controls inside the fridge?[/quote] |
Knowsley
Posted: Tue May 31, 2011 11:01 pm Post subject: |
Some years ago I remember buying the equipment to convert a gas fridge into one that also ran on 240 volts. Having an old fridge myself I have tried to search the internet for a company still making these parts but atlas my search has been unsuccessful. Can anybody help to shread a light, failing that I guess a new fridge, but my model is an old RAM10 and quite small compared to modern all singing and whistling vans new vans
David _________________ Remember - Practice makes perfect! |
alan 869
Joined: 07 Mar 2011 Posts: 388 Location: Linköping Sweden
Posted: Wed Jun 01, 2011 7:56 am Post subject: |
The RAM10 is an Electrolux. I´ve had quite a few over the years. Think I have the instructions for it (in Swedish ) These old ones are very robust. If they stop working they usually need a service at a reputable fridge service shop. Usually need regas etc. Most people have chucked them when they give up. Just need servicing.... |
Knowsley
Posted: Wed Jun 01, 2011 8:28 am Post subject: |
I still have my instruction manual in english!
Another problem with these models is that the gas seperates in the cooling unit so the fridge does not cool. Many people think the fridge is on it's way out and buy a new one. The simple remedy is to take the fridge out of the unit and leave it turned up side down for 24 hours and then re-install, ignite and working again. Just remember to clean the flue at the same time
alan 869
Posted: Wed Jun 01, 2011 10:16 am Post subject: |
Yes, the up side down trick usually works (not always though). I´ve got an Electrolux from the begining of the 50s (meant to be fitted in a kitchen cabinette). The surface of the front of the fridge where the door closes against it is an all wood frame It works perfectly  |
