Thomson window needed
IMPNAX 9
PostPosted: Tue Jun 07, 2011 9:48 pm    Post subject: Thomson window needed Reply with quote
Does anyone know of a Mini Glen being broken for spares please ? We have had a stone go through the frosted toilet window (the lower part ). It would be hard to match a modern glass to blend in. I had already replaced the clear glass on the other side of the frame ,and found that i had to use a different thickness . That made the job very difficult . I can only hope that some kind person has a complete frame or can point me towards a Mini Glen that is disused etc. Any advice would be appreciated . Thank you.
A fan of the 50's and 60's and still living in that time !
Onlyrwd
PostPosted: Fri Jun 10, 2011 11:04 pm    Post subject: Reply with quote
I am breaking a 73 Glenelg which has a split clear and frosted glass window which may be the right size depending on the layout and age , might be a chance...Its near Lincoln
Mick
78 Cavalier GL
78 Manta Berlinetta
67/68 Thomson Glenelg WANTED
Onlyrwd
PostPosted: Sun Jun 12, 2011 8:12 pm    Post subject: Reply with quote
Have sent you a PM about them. Also this may be of use to you for parts.
Thomson Caravan Forum
Mick
78 Cavalier GL
78 Manta Berlinetta
