Trico Windscreen Washers problem
okky
PostPosted: Thu Jul 07, 2011 10:08 am    Post subject: Trico Windscreen Washers problem Reply with quote
I have a Trico Windscreen washer setup in my 1937 7W Ten.
I assume it must have been working to pass the mot last Dec ( prior to my acquiring it ) but now the pipes are broken near the actual sprayers.
I got some more pipe to get them going again.
It runs off a pipe that comes out of the manifold ... I'm guessing this was originally for the wipers, which are now electric. The vacuum from teh manifold is good as there is plenty of suction on the hose when taken off the top of the trico bottle.
There is a sliding flap on the top of the glass water bottle which has snapped off.
When I put water into the bottle and fire up the engine water is immediately sucked back to the manifold.
Would this be because the flap is broken and therefore there is no seal around the hole on the top of the bottle ?Is there any way of testing the system WITHOUT connecting it to the manifold... don't want to suck any more water back hehe.
Thanks for any help
okky
PostPosted: Thu Jul 07, 2011 10:16 am    Post subject: Reply with quote
One more bit of information ... the breaks in the pipes are actually at the washer jet end of the system... ie. AFTER the dashboard control...
It also looks like the LATER trico model as per this one on the holden website
[url] http://www.holden.co.uk/displayproduct.asp?sg=2&pgCode=040&sgName=Hardware&pgName=Washers+%26+Wipers&agCode=0700&agName=Washer+Bottles&pCode=040.009[/url]
PostPosted: Thu Jul 07, 2011 1:38 pm    Post subject: Reply with quote
I would suspect a leak in the pump, between the water side of the pump and the vacuum side.
Nic Jarman
PostPosted: Thu Jul 07, 2011 2:16 pm    Post subject: Reply with quote
Does the windscreen open?
1936 Morris 8 Series 1
1973 MGB roadster
1977 MG Midget 1500
Dax Rush
traction39
PostPosted: Thu Jul 07, 2011 2:54 pm    Post subject: Reply with quote
It sounds as if the pump diaphragm has a leak if water is finding its way back to the manifold.
Do you have a vacuum control knob in the system...ie depress for 2-3 seconds and the pump fills until it can hold no more water. Release button and water sprays over windscreen.
Remember the manifold creates a vacuum condition on one side of the diaphragm allowing this to "collapse" and water from the reservoir to fill the space. Once the space is full of water and you have released the vacuum control knob, atmospheric air (and a spring) will then push it back, and via a couple of one-way valves, flow water to the washer jets.
My pennyworth.
Alistair
okky
PostPosted: Thu Jul 07, 2011 8:06 pm    Post subject: Reply with quote
Thanks for you thoughts guys...
Unfortunately the only person in our house who knows anything about vacuums isnt me ...
My gut feeling was to go with a simple manual push type replacing the control valve on the dash.
I then had a look on ebay and found replacement caps but I could do a simple push pump for a lot less, and I'd understand it ... I push and water comes out... simples
What I may do is try and rig it up out of the car, I think we've a wet / dry hoover at work that feels similar to the vacuum in the pipe from the manifold.
This would also allow me to see if the fact that the filler hole cover is broken and the hole was uncovered the only time I tested it and water went back to the carb.
Thanks again
traction39
PostPosted: Thu Jul 07, 2011 8:25 pm    Post subject: Reply with quote
If you PM me I can send a file about the Vacuum washer...
PostPosted: Thu Jul 07, 2011 11:02 pm    Post subject: Reply with quote
You do not legally need washers if the screen will open and as they are not original anyway why not fit an electric pump (6v?) or even a manual one if you want them to work
Rover P2
Morris Mini Traveller Mk2
okky
PostPosted: Fri Jul 08, 2011 12:38 am    Post subject: Reply with quote
Its a Ford 7W so the windscreen opens from the bottom ... not more then 3 or 4 inches though.
As it already has the tubing and sprayers I think I'll go with the manual plunger type on the dash... nice and simple...
Thanks for all the advice guys Smile
JohnDale
PostPosted: Fri Jul 08, 2011 11:35 am    Post subject: Reply with quote
Hi Okky, I have a manual washer pump. If you want it PM me a name & address, Cheers,JD.
1976 Ford Granada Ghia.
PostPosted: Fri Jul 08, 2011 11:54 am    Post subject: Reply with quote
Even easier! My old Austin still has an early extra (made by Tudor I think), which is powered by a squeezy bottle hanging under the dash! It still works well and I refuse to remove it as it is part of the car's history. I retro fitted at the time washers first appeared. About 1957?
Now what is the "classic"? Me or the car? Confused
Jim.
