fuff66uk
Joined: 20 Jun 2011 Posts: 42 Location: Mansfield,Nottinghamshire
Posted: Sun Jul 10, 2011 7:59 pm Post subject: Sill replacement costs |
I realise this question depends on what is found but can anyone give me a rough price guide for the replacement of an inner and outer sill on a classic ford please.I can get the panels but not sure my welding is up to standard to do the job myself
Thanks
Al |
RobMoore
Posted: Sun Jul 10, 2011 10:18 pm Post subject: |
for the weling alone your looking at anything upwards of £200 a side, depends on the complexity (inners outers etc) tbh if you can grind have a go yourself, brace your door gaps to add strength before cutting out, even pird poos can grind smooth  |
fuff66uk
Posted: Sun Jul 10, 2011 10:23 pm Post subject: |
RobMoore wrote: | for the weling alone your looking at anything upwards of £200 a side, depends on the complexity (inners outers etc) tbh if you can grind have a go yourself, brace your door gaps to add strength before cutting out, even pird poos can grind smooth  |
Do i just brace at the bottom of the door opening just above the sill ? I assume i would need to brace the front and rear door ? Tbh it was the bracing and door gaps that was bothering me |
Joined: 25 May 2011 Posts: 2711 Location: South Cheshire
Posted: Mon Jul 11, 2011 9:19 am Post subject: |
Basically if you weld some sturdy metal across the bottom of the gaps that should do it - the idea is to make sure nothing moves when you cut out the sill section that holds it all in place. You really want to take the doors off as well so there isn't so much weight on the pillars.
Don't put the bracing too far down, remember you need access for cutting and welding the new bits in. And use something that won't easily bend, too, bit of old Dexion upright (other makes of shelving are available). |
fuff66uk
Posted: Mon Jul 11, 2011 2:42 pm Post subject: |
Thanks Mike,that's a great help,i think i'll have a go myself when i get the panels then,plus when the weather is nice enough,i wish i had a garage it's a pain doing everything on the front drive lol |
fuff66uk
Posted: Tue Jul 12, 2011 1:05 pm Post subject: |
I haven't used one of those, I read a lot on the mig-welding forum and reports are not good. For replicating spot welds I tend to use a plug technique, so drill a suitable hole in the top panel, clamp it up and weld through to the other side, then clean off afterwards. Arc welders aren't really suitable for welding car bodywork because the steel is too thing, you need a MIG and some practice.
If you want some inspiration (and have plenty of time to spare) have a look through this thread: http://retrorides.proboards.com/index.cgi?board=usetharch&action=display&thread=70135 - the quality of work on there is amazing. |
fuff66uk
Posted: Tue Jul 12, 2011 5:34 pm Post subject: |
MikeEdwards wrote: | I haven't used one of those, I read a lot on the mig-welding forum and reports are not good. For replicating spot welds I tend to use a plug technique, so drill a suitable hole in the top panel, clamp it up and weld through to the other side, then clean off afterwards. Arc welders aren't really suitable for welding car bodywork because the steel is too thing, you need a MIG and some practice.
That link is awesome Mike,if i can make half as good a job as that i'll be well happy.I am definitely going to have a go at it myself i can't wait to get it here now to asses all the work needed,it is going to be a very long project due to funds being permanently low so parts will be sourced as & when i can afford them but i guess that will make me appreciate the end result even more |
