1935Hillman
Posted: Tue Jul 19, 2011 8:33 pm Post subject: Rubber engine mounts |
Does anyone have any idea where I can get rubber engine mounts made or sourced. I need round blocks with a hole in the centre to take the spacer.
Outer diameter 60mm
Inner diameter 25mm
Thickness 40- 45mm
I did buy some very nice anti vibration blocks of the exact dimensions but they have a moulded in fixed threaded bar sticking out at each end which means they will not fit inside the brackets on the chassis.
Does anyone turn rubber on a lathe?
Many thanks,
Tim |
