Bayliss Thomas
Posted: Tue Jul 26, 2011 9:20 am Post subject: Vacuum wiper motor |
| The vacuum wiper motor (Trico) has packed up, I replaced the rubber feed tube but still not working. The remaining feed tube is copper, I cannot hear any air escaping and so assume its the motor itself faulty. Anyone know where I can have this overhauled/repaired? Thanks. |
Posted: Wed Jul 27, 2011 5:34 pm Post subject: |
You don't say what car it is on.
Does it have vacuum reserve tank?
A common problem with 100E Fords was corrosion under the vacuum tank, which cannot be seen in situ, letting air IN. Other vehicles might suffer the same problem. _________________ Quote from my late Dad:- You only need a woman and a car and you have all the problems you
Bayliss Thomas
Posted: Thu Jul 28, 2011 12:16 pm Post subject: |
Its on my 1928 Vauxhall 20/60 saloon, it has no reserve tank. I took the motor off the car, started the engine and felt the air pressure coming from the feed tube to the motor, it was weak. I have been advised that the leather paddle may need oiling and so I will do that today but as the pressure is so low it points to a leak in the feed somewhere, I just wish the feed pipe was not buried deep within the car structure  |
Posted: Thu Jul 28, 2011 10:15 pm Post subject: |
There should be no pressure from the pipe to the motor! It should be "sucking" air in surely? It is a VACUUM pipe and it should "suck" like a vacuum cleaner!
Bayliss Thomas
Posted: Thu Jul 28, 2011 10:20 pm Post subject: |
I have managed to locate and repair the fault, it was the needle switch which was bunged up with crud. Cleaned it out and hey presto  |
