Rdover
Posted: Mon Aug 08, 2011 9:21 am Post subject: 1912 Magneto timing |
After a recent failure, my magneto was rebuilt again and now I'm trying to get the timing sorted so I can get the car running in time for the Biggar Albion Rally this weekend.
Its a side valve with priming pots so I've 'found' tdc by leaving the primer on the front (No. 1) cylinder open and turing the engine until I hear the hissing (compression) stop. I check it is not on the exhaust cycle by putting my finger on the primer and feeling/hearing pressure.
At TDC (roughly) I move the flywheel back by 10deg, calculated by taking the circumference and dividing by 36 and measuring out. There are marks on the flywheel left by the original rebuilder which sort of line up with what I've found.
At this point I set up the magneto at Cyl 1 and set the points with the advance/retard mid way in the adjustment becuase I can't seem to either figure out or remember which way is advance nor which way is best for starting!
Problem. It wont start and I'm not even getting a puff or 2. There is a good spark (I still need to check all the HT leads, connections and plugs again). What I am missing or getting wrong? _________________ Richard |
Rdover
Posted: Mon Aug 08, 2011 9:31 am Post subject: |
just found this on http://www.magnetorepairs.com/tip1.shtml
| Quote: |
Find Top Dead Centre (TDC).
By adjusting the camshaft timing, set the LT igniter contact to break at TDC with any advance/retard lever set to full retard. Allow sufficient clearance on the ignitor adjusting system for the contact to snap closed. Say 1/32nd inch free movement after the contacts have closed.
Adjust the magneto timing such that as the igniter breaks, the armature pole is about 1/8th to 3/16th inch away from the carcass pole, having just left the pole in its normal direction of rotation.
If the system is fixed timing it probably makes sense to start as above to get the engine running. Then advance the ignitor break, and the magneto timing so that the relationship between the armature position and the igniter remains the same, until the engine kicks back on starting. In the case of my 1904 Berliet this is equivalent to about 40° maximum advance. |
So
"advance" means making it spark closer to TDC
"retard" means making it spark earlier in the cycle
Starting should be attempted on full retard. Normal running should be on retard with an extra push coming from advancing the spark?
Or am I confusing myself even more? _________________ Richard |
Posted: Mon Aug 08, 2011 10:34 am Post subject: |
'Retard' usually means later, that is, especially with a hand-cranked engine, a few degrees AFTER TDC.
When the engine is running, the spark is advanced so that occurs before TDC for best running results.
Hand-cranking with a spark occuring before TDC leads to broken arms! _________________ Dane- roverdriver but not a Viking. |
Posted: Mon Aug 08, 2011 6:23 pm Post subject: |
Good explanation! _________________ Rover P2
Rdover
Posted: Tue Aug 09, 2011 4:17 pm Post subject: |
| roverdriver wrote: | 'Retard' usually means later, that is, especially with a hand-cranked engine, a few degrees AFTER TDC.
Hand-cranking with a spark occuring before TDC leads to broken arms! |
After several hours of trial and error I ended up hurting my shoulder (they are knackered anyway) and bashing my knuckles off the chassis when I lost grip. It was firing, sort of, and almost running so I'm close but it needs professional attention.
I've found a local classic/vintage repair place that can sort it out. They're going the whole hog and checking compression, finding TDC properly and setting the valves.
I may miss this weekend's run but its far better to have the car starting and running reliably so I can enjoy it without killing myself! _________________ Richard |
