gillberry
Posted: Thu Jun 16, 2011 7:22 pm Post subject: Caravan wheel needed |
| Hi all having just had a blow out and discovered that the spare was the wrong pcd we are now after a spare of the correct size . We are after a 4 stud 13" with a 4 1/2" pcd and a 2 3/4" centre hole . Originally these wheels had 3 studs on for the hub cap to be applied and to the best of our knowledge were made for b&b trailers .Any help or advice would be much appreciated . |
gillberry
Posted: Fri Jun 17, 2011 3:27 pm Post subject: |
A pic of said wheel ,
sheffieldcortinacentre
Posted: Sun Jun 19, 2011 8:22 pm Post subject: spare wheel |
the following should be the right pcd but you'll have to check centre bore
austin allegro/1100/1300/1800/2200/cambridge/princess/maestro van (only).
datsun (70's rwd) bluebird /240/260Z.
triumph TR range/stag
volvo S40/V40 |
rivet
Posted: Tue Aug 09, 2011 7:28 pm Post subject: |
Hi Gilberry
did you find a wheel for your van . i am looking for one the same as yours,
my van is a regency cruiser, do you have any leads?
regards
rivet |
gillberry
Posted: Tue Aug 09, 2011 7:55 pm Post subject: |
| Hi we did eventually get a wheel from a floow club member . It does seem though that they are thin on the ground . Best wishes in your hunt sorry we cannot help you more . |
