JC22
Posted: Sun Sep 04, 2011 5:32 am Post subject: ford pop 103E pistons |
I am looking to hone the bore and re-ring the pistons in my Ford Pop 103E. Can anyone tell me what would be stamped on the piston tops of a standard size piston for this model, the pistons I have removed are stamped RP 2109pb TOP 008 ND.
Jason |
Posted: Sun Sep 04, 2011 3:00 pm Post subject: |
Whatever your reasons for honing the bores, I would suspect that if the car has done enough miles to need new big-ends The bores will no longer be suitable for standard pistons. The bore diameter after honing needs to be compared with original spec. and pistons obtained accordingly.
Armed with that info. any competent supplier should be able to advise.
DELETED Guest
Posted: Fri Oct 21, 2011 4:27 pm Post subject: Increasing piston size |
| DELETED |
