Oil to use in an oilbath air cleaner?
PostPosted: Fri Sep 16, 2011 7:30 pm    Post subject: Oil to use in an oilbath air cleaner? Reply with quote
What oil should I be using in an oil bath air filter? I'm in the process of fitting a NOS filter to the Dodge, but I'm curious as to what I should put in it?
thanks, R
PostPosted: Fri Sep 16, 2011 8:08 pm    Post subject: Reply with quote
Hi Rick,
On my old VW's I always used normal engine oil, I suppose its only there to catch dust after all!!
Found this discussion about VW ones for you which might be of interest...
http://www.thesamba.com/vw/forum/viewtopic.php?t=337399
Ray the rocker
PostPosted: Fri Sep 16, 2011 8:12 pm    Post subject: Reply with quote
On most commercials from the fifties to the seventies,we used to use castrol xl--a very light viscosity but any 20/50 would be suitable imo.
Take care not to exceed the reservoir line or arrow markings as you`ll get problems with engine air volume into the venturi being starved.
Cheers---Ray the Rocker....
exbmc
PostPosted: Fri Sep 16, 2011 8:42 pm    Post subject: oil Reply with quote
Generally, we used to fill the oil bath with whatever the engine was having in it. I still service a series2 Land Rover, and that has the same 20w/50 as the engine. As D4B says, it's only to catch dust, and as oil prices are going up, I would tend to use any old own brand from the supermarket.
stuchamp
PostPosted: Sat Sep 17, 2011 4:59 am    Post subject: Reply with quote
Same as exbmc mentioned. Back in the day usually 30w summer and 10w winter in the northern areas. Just use the oil that you're using in the crankcase.
