External Oil Filters (For side valve engines)
Dobbin
PostPosted: Fri Sep 13, 2013 9:10 pm    Post subject: External Oil Filters (For side valve engines) Reply with quote
I know a lot of early side valve engines didn't have oil filters or water pumps fitted as a factory standard item (hard to believe now a days)but it's true. If you've fitted an aftermarket unit to enable the use of a spin on filter then it's very possible that your using a Crosland 2022 filter. Whilst looking for a reasonably priced replacement I found out that a filter from a 1987 era 1.1L Fiesta is the same item, or so I was informed. This helped immensely as there are loads of web sites that you can find filters on for this vehicle. One I found recently that was I thought very reasonably priced was here http://www.carparts4less.co.uk/oil-filter Postage was free and they were delivered by UPS courier. Hope I've saved someone a pound or two.
