buying a new battery What amp and so on
TopCat327
PostPosted: Wed Mar 14, 2012 7:51 pm    Post subject: buying a new battery What amp and so on Reply with quote
what am i looking for when buying a battery for my 1962 a40?
PostPosted: Wed Mar 14, 2012 8:06 pm    Post subject: Reply with quote
It'd be worth picking up a workshop manual, or at the very least a handbook, for the A40, it'd help with the rebuild a lot.
It'd be a 12v battery, not sure of the Amps rating offhand.
Check to make sure whatever battery you buy, has the terminals the correct way around to match the length of your two battery leads, otherwise you'll end up having to make new leads to reach.
PostPosted: Wed Mar 14, 2012 8:56 pm    Post subject: Reply with quote
The first Farina A40 used a Lucas BT 7A which is a 43 amp-hr battery.
bob2
PostPosted: Thu Mar 15, 2012 10:49 am    Post subject: Reply with quote
my minis both have a 45 amp battery, one does also share starting duties on the hunter so I say with such a battery you should be ok for the a40.
however as rick suggested make sure the polarities are in the correct position
