Bazz57
Posted: Wed Mar 14, 2012 9:52 am Post subject: |
Hi Bazz,
If you are copying the addresses from Photobucket then use the bottom one. It includes the [img] necessary for displaying in your posting.
_________________ http://www.nostalgiatech.co.uk
Bazz57
Posted: Wed Mar 14, 2012 10:11 pm Post subject: 1956 Ford Thames |
Hi Rick, not sure whether this truck was NZ built or not, I have owned it for 24 years and have had it garaged in NZ for 22years. I am now importing it into Aussie, as that is where I am living. Can't wait to get it here, so I can start restoring it.[/url] |
Bazz57
Posted: Wed Mar 14, 2012 10:17 pm Post subject: 1956 Ford Thames |
Hi Peter, thanks for the information, still having trouble trying to get the little thumbnail photo displayed by my username. |
Bazz57
Posted: Fri Mar 16, 2012 9:58 pm Post subject: 1956 Ford Fordson Truck |
Does anyone know what model Fordson truck uses a 16 inch wheel, because I have 2, my truck takes 15 inch. |
Posted: Fri Mar 16, 2012 10:44 pm Post subject: |
I have a E83W like yours but the UK version, it is on 16" wheels and it is 1956 too.
Good to see yours!
Posted: Fri Mar 16, 2012 10:44 pm Post subject: Re: 1956 Ford Fordson Truck |
Bazz57 wrote: | Does anyone know what model Fordson truck uses a 16 inch wheel, because I have 2, my truck takes 15 inch. |
E83W pickups, in the UK at least, all came with 16" rims - with a wider section than those 16s fitted to some saloons.
Vans were on 18"s, some estates also came on 17"s.
The only 15" rims I've known to be fitted to sidevalve Fords were those made by Ballamy and usually fitted to 1172 specials, they look very different to normal Ford wheels. Maybe 15" Ford pattern rims were fitted to export trucks? I've not heard of it but it's a possibility.
Some Holden and VW 15" wheels had a stud pattern very similar to Fords of the era (my Bedford ute has 15s on it but it should have 17s), so there's a chance that these rims could find their way onto a Ford, but they too would look quite different to a stock Ford wheel.
Bazz57
Posted: Wed Mar 21, 2012 4:23 am Post subject: 1956 FORD THAMES |
T0
Rustrecs do you know anybody in NZ who would want 16inch wheels for Fordson. Baz |
Bazz57
Posted: Tue Mar 27, 2012 4:48 am Post subject: 1956 Ford Thames whos got the hydraulic brake set up |
Who has got the hydraulic brake set up for the Ford Thames |
Bazz57
Posted: Tue Mar 27, 2012 10:41 pm Post subject: Hydraulic Brakes |
Hi Rick, do you know anyone that has put hydraulic brakes on a Ford Thames, I am wanting to put hydraulic brakes on my truck. Bazz |
Mog
Posted: Thu Mar 29, 2012 7:54 am Post subject: |
Bazz57, after all these years, you have finally woke up to the fact that the best place to live is Aus. ! They did say at one time, that at the present rate of departure from NZ , that there would be nobody left after x numbers of years ! They did ask the last person to leave to switch off the lights ! Is that you ? |
Mog
Posted: Thu Mar 29, 2012 8:00 am Post subject: |
Keep it as it was, do not change the brakes. Are you going to make a hot rod from it ? You will get more money for it,if it is kept as it was. Just my view. |
