Not really a classic
victor 101
PostPosted: Mon Apr 16, 2012 5:07 pm    Post subject: Not really a classic Reply with quote
Looking for some advice, I have an early Vanroyce caravan which is very original and in very good condition. My only concern is the first layer of the laminate flooring is beginning to peel in places underneath.(very thin layer), what would be the best way to seal the floor from further deterioration?.
christine lowery
PostPosted: Tue Apr 17, 2012 2:25 pm    Post subject: Reply with quote
when you say laminate do you mean that the plywood floor base is lifting and feels spongy when you walk on it
chris Question
victor 101
PostPosted: Tue Apr 17, 2012 5:00 pm    Post subject: Reply with quote
chris Question
Hi, No, inside is solid, as is underneath, its just like a veneer that is peeling off from the underside, and I would preferably like to stop it getting any worse. I wondered if there was something like the wood preserver that you put on your garden fence that people use on their floors to protect it from road spray.
Rod.
Uncle Alec
PostPosted: Wed Apr 18, 2012 1:00 pm    Post subject: Reply with quote
I think probably that the "veneer" is the top (bottom?) layer of a plywood sandwich. That being the case, I would cut away all loose stuff then use Waxoyl underseal, the thick gooey black stuff.
Make sure you don't contract veneeral disease.
victor 101
PostPosted: Wed Apr 18, 2012 6:59 pm    Post subject: Reply with quote
Didn't really want to use underseal because to be honest I wouldn't buy a caravan with underseal underneath for fear of what its covering up. Was hoping something like creosote which would protect it without hiding it.
Uncle Alec
PostPosted: Wed Apr 18, 2012 7:05 pm    Post subject: Reply with quote
Waxoul underseal isn't like bitumen underseal; it's more a thick version of the injectable stuff. It's ,er, waxy.
I used to make my own by adding black Dylon to the sprayable Waxoyl and then thickening it over some (electric!) heat, but for years they have sold a brushable version.
You can re-energise it by spraying thinned-down 'real' Waxoyl on every couple of years to stop it skinning.
Buy a small tin and have a look ; it doesn't harden up and lose adhesion like the traditional underseals.
