alec.elliot
Joined: 28 Feb 2012 Posts: 58 Location: Worcestershire
Posted: Tue Jan 15, 2013 10:52 pm Post subject: Morris 8 Series 1 Radiator Grille Honeycomb |
Hi there
Do any forum members have ideas or experience about how to clean up the honeycomb on the radiator grille of my Morris 8 Series 1.
Mine is intact but looks dirty and fragile. Would these be painted or untreated?
All the best
Alec |
welder
Joined: 26 Nov 2007 Posts: 265 Location: North Warwickshire
Posted: Wed Jan 16, 2013 9:27 pm Post subject: |
Hi Alec, mine was much the same as you describe yours. I had mine chemically stripped and then powder coated in satin black.
I asked the guys at the powder coaters to put plenty of powder on, which they duly did. It all came out rather well.
Ian |
Posted: Wed Jan 16, 2013 9:34 pm Post subject: |
An old friend of mine recommended Oxalic Acid crystals dissolved in water and poured into a pre-war radiator to clean the inside. I have used this method (crystals from Ebay) and I was very pleased with the amount of gunge it removed and how clean it looked; so much so that I also cleaned out the block with it.
http://www.ebay.co.uk/itm/500g-Oxalic-acid-great-cleaner-rust-remover-/140426948733?pt=UK_BOI_Medical_Lab_Equipment_Lab_Supplies_ET&hash=item20b219307d
If this stuff doesn't harm the inside I see no reason why it would harm the outside. you would obviously need a big plastic tray and a fair amount of the crystals but it might be worth a try if, like me, you like to be self-contained with your restorations. |
