Fuel proof "rubber"
john-saab
PostPosted: Sun Apr 15, 2012 12:14 pm    Post subject: Fuel proof "rubber" Reply with quote
I have a petrol filler cap that uses a large "rubber washer" to seal the cap onto the filler neck. The "rubber" has perished and I would like to replace it. I use the quotation marks as i'm guessing the seal is made from something more than standard rubber (1960's car) what could I use to make this washer..it needs to be unleaded fuel proof and long lasting?
Would Nitral work or will normal rubber do?
Rust Junky & oil addict.
PostPosted: Sun Apr 15, 2012 12:30 pm    Post subject: Reply with quote
I had a similar challenge some time ago; found this link:
http://www.par-group.co.uk/rubber-polyurethane/
john-saab
PostPosted: Sun Apr 15, 2012 12:40 pm    Post subject: Reply with quote
Excellent and fast work Dave..Nitrile seems to be the material of choice!
Thanks again!
P3steve
PostPosted: Mon Apr 16, 2012 12:12 am    Post subject: Reply with quote
Had to get a new large "rubber washer" for the petrol cap on my 1949 Rover for an up and coming MOT and for a quick and temporary fix as I didnt have time to order one I cut one out of an old inner tube 5 years later its still in good condition showing no signs of perishing.
richardlw
PostPosted: Tue May 01, 2012 12:48 pm    Post subject: Reply with quote
My Corvair uses a cardboard disk over a slightly conical brass springy disk.
Richard's Cars - NEW **
Motor oil for Flat Tappet Engines
Transmission oil
baconsdozen
PostPosted: Thu May 31, 2012 8:34 am    Post subject: Reply with quote
I made a 'temporary' replacement accelerator pump diaphram for my transit V4 a couple of years ago from a nitrile glove. Its still working.
PostPosted: Fri Jun 01, 2012 8:13 am    Post subject: Reply with quote
P3steve wrote:
Had to get a new large "rubber washer" for the petrol cap on my 1949 Rover for an up and coming MOT.....
Apparently it should be a leather washer fitted to the Rovers
ROVER
One of Britain's Fine Cars
PostPosted: Fri Jun 01, 2012 10:41 am    Post subject: Reply with quote
Well, leather is an easy fix. I needed something similar for a steel can that I use for petrol, and simply cut some leather from an old boot. (I live with the philosophy of 'throw nothing away, it will come in handy some day'!)
