1924 Dodge Four tourer
Goto page Previous  1, 2, 3, ... 17, 18, 19  Next
PostPosted: Tue Jul 17, 2012 3:53 pm    Post subject: Reply with quote
Re-commissioning has begun, starting at the front end.
There was a noticeable amount of play in the o/s/f wheelbearing, so the bearings on both sides were removed and given a wash down with old petrol (they were very gummed up and dirty), then packed with fresh grease. Surprisingly they weren't too worn, and when re-fitted - correctly this time - they adjusted up fine.
Prior to this I had a look at the leaking exhaust, it was blowing at the manifold/downpipe joint quite badly. An attempt to seal it better with a new seal improved it but not enough. Small drillings around the top of the downpipe (something to do with an exhaust gas heater I think) weren't helping either. In the end I took the full system off and found a hole near to the silencer. Rather than patch it up, it went off today for a new one to be made, using the original as a pattern.
On the dash is a control I've not come across before, produced by Leggett (?)
It has settings for Brake, Extra Air and Off. My guess is some auxiliary engine braking arrangement, of a type found on some lorries, but I'm happy to be put right on this one Smile
Still lots of fiddly things to do, but progress is being made. For now I'm concentrating on the MOT items only, niceties such as replacing a couple of later auxiliary gauges on the dash can wait.
Rick (OCC Admin)
PostPosted: Sat Jul 21, 2012 10:00 am    Post subject: Reply with quote
Hi Rick,
I've just spotted your "new" car, prompted by Penman's reference to big and little elsewhere. I think age shouldn't be belittled and it should be old and new.
I'm looking forward to reading your experiences of proper vintage ownership.
What is the device on the running board below the horn? Tyre pump?
1939 SS Jaguar 2 litre saloon
PostPosted: Sat Jul 21, 2012 4:40 pm    Post subject: Reply with quote
peter scott wrote:
Hi Rick,
But should "old" be as in old age (the tourer), or the one I've had for longest (the truck)? mmmmm I might just stick with "big" and "little" for the timebeing..!
Yes that's an American tyre pump attached to the running board, it has a patent date of 1917 (the name escapes me, but I found an advertisement for it in an American motor mag of c1920).
The new exhaust system should be here next week, so that can go on.
Rick (OCC Admin)
PostPosted: Mon Jul 23, 2012 9:02 pm    Post subject: Reply with quote
Both headlamps were dismantled and cleaned internally this evening, once I'd found out how they come apart! Each headlamp has one single filament bulb in it (45w), the switch from main to dip beam being via a coil dimmer attached to the rear of the headlamp switch, not something I'd come across before.
Rick (OCC Admin)
PostPosted: Fri Aug 31, 2012 4:30 pm    Post subject: Reply with quote
I've not updated the thread in a while, but things are progressing and hopefully an MOT attempt isn't too far away now Smile
Some recent photo messing/ageing:
Rick (OCC Admin)
PostPosted: Fri Nov 16, 2012 3:29 pm    Post subject: Reply with quote
MOT successfully navigated today, next to do - the registration
Rick (OCC Admin)
PostPosted: Fri Nov 16, 2012 3:32 pm    Post subject: Reply with quote
Nice one Rick Cool Cool Cool
PostPosted: Fri Nov 16, 2012 10:16 pm    Post subject: Reply with quote
The fact that it was a glorious sunny, if chilly, day helped a lot - roof down, our hats pulled down low as we motored along to the MOT garage - best drive I've had in quite a while Smile Pic or two to follow
Rick (OCC Admin)
PostPosted: Sat Nov 17, 2012 8:50 am    Post subject: Reply with quote
Photo after our return, I did take some pics at the garage but as they're on my phone, and I've yet to re-locate the correct lead, they might have to stay there for a while Rolling Eyes
We were surprised at how well it rolled along, and the ride - because of the wheelbase, large diameter wheels and springy seats - was quite impressive. It was the first time out for it since arriving in the country, so something of a voyage into the unknown!
Rick (OCC Admin)
PostPosted: Sat Nov 17, 2012 11:49 am    Post subject: Reply with quote
Hi Rick
If you have a card reader on your computer you can always try putting the card from your phone in it.
My phone has a mini SD and I have an SD adapter for it.
I have also used the adapter to transfer to my camera on occasions.
But don't re-format if you do that.
PostPosted: Thu Nov 22, 2012 2:02 pm    Post subject: Reply with quote
There's always Dropbox. Then you don't need a lead at all, just wifi.
PostPosted: Thu Nov 22, 2012 3:02 pm    Post subject: Reply with quote
I'll have a check of the card and see what gives, I think I have a reader around here somewhere.
Got the dating certificate through today so nipped down to the DVLA offices and applied for an age-related number. Friends of mine did the same this Monday just gone and got their new paperwork and tax disc through on Wednesday morning - can't complain at that service!
Rick (OCC Admin)
PostPosted: Tue Nov 27, 2012 5:18 pm    Post subject: Reply with quote
Reg. details and first tax disc arrived in today's post, woohooo Smile
Rick (OCC Admin)
PostPosted: Tue Nov 27, 2012 5:34 pm    Post subject: Reply with quote
Lands end to John of Groats next summer
PostPosted: Sun Dec 23, 2012 5:24 pm    Post subject: Reply with quote
In preparation for a New Year's Day gathering, the Dodge was taken for a spin into town - its first post-MOT run out. It was chilly but bright, so quite agreeable. We were spotted by another forum regular, who I believe happened to have a camera close to hand as we pulled up behind his modern.
Today was the first time it had visited a UK petrol station Smile
Rick (OCC Admin)
Page 2 of 19
