Reaming towing eye
Bayliss Thomas
PostPosted: Thu Jul 26, 2012 11:34 am    Post subject: Reaming towing eye Reply with quote
I need to find an engineering shop that will be able to drill/ream out the towing eye on my vintage caravan drawbar. I do not want to remove the drawbar from the caravan as it is a nightmare job to bolt the thing back into place.
I have a new towing pin which is 19mm and the tow eye is about 17mm. If somebody can offer me a link as to who may be able to drill this out please. I live in Diss, Norfolk, so nearer the better. Thank you.
Uncle Alec
PostPosted: Thu Jul 26, 2012 1:43 pm    Post subject: Reply with quote
Plenty of 18.5mm HSS drill bits and 19mm reamers on eBay.
Bayliss Thomas
PostPosted: Thu Jul 26, 2012 2:38 pm    Post subject: Reply with quote
Thanks Uncle Alec, ordered two 20mm HSS drill bits (blacksmiths type) which the shank will fit my DIY drill chuck. Panic over.
Uncle Alec
PostPosted: Thu Jul 26, 2012 2:53 pm    Post subject: Reply with quote
At the risk of teaching Granny to suck eggs:
Ensure the eye is held totally rigid before drilling.
Plenty of suitable lubricant - the aerosol cutting oil from Screwfix I find handy.
I would have bought 19.5 drill and a 20mm reamer, but it depends on how clinically accurate the hole has to be - I suspect not very.
All this assumes that the steel is drillable. Probably, given the age of the eye.
PostPosted: Thu Jul 26, 2012 4:14 pm    Post subject: Reply with quote
Those sizes sem to be quite small, I have a book/catalogue from Indespension and it has a couple if info pages about towing eyes and all it mentions are 30,40,50 and NATO 76mm sizes. it also has diagrams showing correct fitting size of throat etc.
I know taking 3mm out only reduces the thickness of the ring by about 1.5mm but is there a danger of it weakening the ring too much?
Uncle Alec
PostPosted: Thu Jul 26, 2012 4:30 pm    Post subject: Reply with quote
The "new" pin is probably ¾"; quite a common pin size pre-war.
The "old" hole could be ½" but worn a bit?
If the tow eye is anything like normal it will be at least ½" section hopefully, so no worries there.
Bayliss Thomas
PostPosted: Fri Jul 27, 2012 10:38 am    Post subject: Reply with quote
Thank you for good advise and comments.The tow draw bar is original fitted into a new steel chassis (25 years ago). Measured up and I will be leaving 17 /18mm of steel surrounding the tow eye after drilling out for new pin. The thickness/depth of the metal part of the tow eye is 9/10mm and seems to be extremely solid.
My caravan weighs in at about 3/4 ton and the new draw bar tow devise I have purchased to fit onto my car is rated at 1.5 ton.
The new pin that came with the tow ball/pin/jaw combined is 19mm. Again thank you for advise / comments.
PostPosted: Sun Jul 29, 2012 11:32 am    Post subject: Reply with quote
Surely, in view of the age all parts would have been manufactured to Imperial Measurements?
Why introduce Metric dimensions?
Jim.
Uncle Alec
PostPosted: Sun Jul 29, 2012 11:56 am    Post subject: Reply with quote
I guess he has bought a new tow hitch with removable pin. They are available only in metric as far as I know.
Bayliss Thomas
PostPosted: Sun Jul 29, 2012 7:09 pm    Post subject: Reply with quote
Yes indeed, no choice with some of these details, I don't suspect many will be getting out the callipers to prove my errant ways Wink
PostPosted: Sun Jul 29, 2012 7:31 pm    Post subject: Reply with quote
Very true, But I always have in mind how many Imperial nuts and bolts on older vehicles are replaced with Metric as "near enough".
Worse still though was when a friend replaced wheels on Triumph hubs with Fiat wheels as "near enough" (in p.c.d.). He never could understand why his "near enough" wheels kept coming loose.
Jim.
welshrover
PostPosted: Mon Oct 01, 2012 1:18 pm    Post subject: Reply with quote
make sure you hold on tight to your drill, with drills that size in a hand drill. you could be in for a broken wrist if your not careful Sad
Bayliss Thomas
PostPosted: Mon Oct 22, 2012 10:30 am    Post subject: Reply with quote
Yup I found out exactly what you meant by the warning! Happily no broken wrist.
