Can anyone recommend a decent make of battery?.
baconsdozen
PostPosted: Wed Dec 12, 2012 2:30 pm    Post subject: Can anyone recommend a decent make of battery?. Reply with quote
My fairway taxi seems to kill its battery on a regular basis every winter.The last one wasn't cheap and has only lasted just over a year. Anyone got any recommendations for a decent heavy duty battery?.
Greg
PostPosted: Wed Dec 12, 2012 3:13 pm    Post subject: Reply with quote
If you're not worried about looking like a 'period' battery and you require 12v
Optima batteries are superb.
http://m.optimabatteries.com/
All the best,
Greg
PostPosted: Wed Dec 12, 2012 4:32 pm    Post subject: Reply with quote
It is possible that the batteries we can buy here in Canada, differ from those I used to buy back in the UK.
First they have to deal with extreme cold. Providing the block heater is plugged in, so the oil is warm, then there is no problem cranking at -40C.
Second, they seem to last much longer. The truck is still running on its original battery, over 5 years old. We have friends who have vehicles that are 10 years old and still on the same battery.
I seem to remember back in the UK that we bought batteries more often.
Incidently. A battery for the truck would be about $80 Cnd (approx £55) is that reasonable over there ? The $80 here is OK.
baconsdozen
PostPosted: Wed Dec 12, 2012 5:11 pm    Post subject: Reply with quote
That seems pretty cheap for a truck battery.
My Dagenite merc battery lasted ten years and the Lucas one on the rover about the same but its hard to sort out the good from the junk in the UK now so much cheap tat is imported and passed off as being of good quality.
welshrover
PostPosted: Wed Dec 12, 2012 5:45 pm    Post subject: Reply with quote
a lot of lucas stuff these days is tat. its not original just cheap chinky stuff in lucas boxes. you can tell it by the edges of the lucas lettering its not crisp its blurry . Rolling Eyes
PostPosted: Wed Dec 12, 2012 5:49 pm    Post subject: Reply with quote
This may be of interest. Not my photos, so not the best. Costco, charge $9.50 if you don't bring the old battery back. Attempt to stop them going to the landfill.
http://mikenv.hubpages.com/hub/Kirkland-Car-Batteries
PostPosted: Wed Dec 12, 2012 7:13 pm    Post subject: Reply with quote
I get 8-10 years from batteries whther on dynamo or alternator on our 7 classics.
I currently use YUASA 069 on some of the Rovers/Land Roverswith 2 yr guarantee and have an Exide Excel 063 with a 3 year one on the Mini.
Try this place
http://www.ebay.co.uk/itm/290710526947?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1497.l2649
I had a Durastart fail in 12 months but that was replaced FOC
I have had various makes but I think its useage and the state of the charging system that determines life - under/oversize capacity batteries will fail earlier than the correct capacity for the load
Rover P2
Morris Mini Traveller Mk2
baconsdozen
PostPosted: Thu Dec 13, 2012 12:05 pm    Post subject: Reply with quote
Thanks but I'm very wary of buying batteries etc on ebay,you can't leave feedback after a year saying battery died etc.
I'd forgotten about Yuasa, I have used their batteries on boats and found them excellent,I'll see if they do one suitable for the taxi.
I know there's a lot of 'iffy' Lucas stuff about,years ago I was offered a load of brake pads familiar looking boxes but a pity they'd spelt Girling with a 'D'.
Kelsham
PostPosted: Thu Dec 13, 2012 3:47 pm    Post subject: Reply with quote
Is your system charging correctly? One year for a battery seems very poor.
Even my BSA Trike used to last two years when I ran it without the dynamo.
I just ran it on battery for the coil ignition and recharged it when I could.
Once the primitive three brush system was repaired, the next battery lasted five years.
I would think any modern battery should last more than a year.
Regards Kels.
PostPosted: Thu Dec 13, 2012 6:09 pm    Post subject: Reply with quote
Hi Phil
I can understand undersized having problems, but why does an oversized capacity cause problems?
PostPosted: Thu Dec 13, 2012 10:32 pm    Post subject: Reply with quote
Last battery I had lasted 6 or 7 years, and was only a cheapy from the local factors - but I had a conditioner hooked up when the car wasn't being used regularly (which was most of the time). Keeping it exercised seems to help a lot.
PostPosted: Thu Jan 17, 2013 2:09 pm    Post subject: Reply with quote
I bought my first battery for my old Jag from:
http://www.marine-batteries.com/
This was beginning to show signs of weakness after 10 years of intermittent use (6 months each year) but when I went back to complain Wink they refused to replace it so I just bought another one from them. The replacement has done about 9 years now but shows no sign of weakening yet.
Proper hard rubber batteries. They do all types. Not just marine.
Churchill Johnson
PostPosted: Thu Jan 17, 2013 9:56 pm    Post subject: Reply with quote
Try Varta or Bosh not cheap but good. with the Varta stop start battery one get's two year's road side assistance if the battery fail's.
PostPosted: Thu Jan 17, 2013 11:21 pm    Post subject: Reply with quote
Over sized batteries will not receive sufficent "deep" cycling so may not last as long as a correctly sized one that will discharge/recharge sufficiently besides paying for CCA that you will never need
Rover P2
welshrover
PostPosted: Thu Jan 17, 2013 11:30 pm    Post subject: Reply with quote
i try to get ones you can maintain yourself ,fill etc .not to keen on sealed ones .maintenance free i think they call them. i like too see whats happening inside water levels and the like .same with grease points i like to be able to grease them myself. i dont trust sealed for life uj's ,ball joints track, rod ends .and sealed wheel bearings. give me the taper rollers that you can clean ,repack and retension ,
