Dent pullers
traction39
PostPosted: Wed Dec 19, 2012 8:58 pm    Post subject: Dent pullers Reply with quote
Simple question. Do they work?
I have a couple of slight dents on my son's VW Fox's bonnet from hand prints when pushing it out of the snow! Cannot get access from behind as the "reinforcement" is in the way. Most comments suggest that they are useless unless on a completely flat surface...or maybe they were very cheap pullers?!
Comments or suggestions for removal would be well received.
Alistair
PostPosted: Wed Dec 19, 2012 9:26 pm    Post subject: Reply with quote
Hi Alistair
They do work, but the cheap DIY ones don't have much suction, if the metal hasn't stretched you may have some success .
Tricks like heating the dent up with a hair dryer may help in conjunction with a suction puller, it's difficult to assess without seeing the dents.
You can often get a thin pry behind reinforcements, to encourage the dent out, these can be easily fabricated from odd bits of flat steel, round any corners and put a shallow curve in the business end. Remember modern car body work is made from very thin steel, traditional tools can be too heavy, rubber hammers and dollies are the order of the day.
traction39
PostPosted: Wed Dec 19, 2012 9:53 pm    Post subject: Reply with quote
Dave,
Thanks for the reply. I was thinking along the lines you mentioned -body spoon type dolly. They are the type of dents that have no creases and would probably push out if there was access from behind...panels are very cheap!!
Alistair
Inglewood
PostPosted: Wed Dec 19, 2012 10:07 pm    Post subject: Reply with quote
The latest method of dent pulling is by using glued pads, have a look at You Tube for 'PDR Glue pulling'.
Products are available on ebay.
There is a skill involved but the results are a retail quality and you do not need to refinish the panel.
