ts210
Posted: Wed Feb 19, 2014 1:12 pm Post subject: MGB V8 PROJECT-LAND/RANGE ROVER 4 POT CALIPERS SAME AS SD1?? |
Anyone know if the 4 pot calipers on the old land and range rovers are the same as used on the rover sd1?
I can't afford shiny new calipers that cost an arm and a leg so I'm trying to source cheaper alternatives for my MGB V8 project.  |
3xpendable
Posted: Tue Mar 04, 2014 9:42 am Post subject: |
What size/power Rover V8 you fitting TS? Because short of it being a fire breathing monster if you just fit performance pads in the standard calipers to start then that should be ok for road use. Its what I'm doing with mine.
I don't think any of the options you suggested are the same plus even if you got Princess 4 pots they are heavy and expensive. Might be better saving up for decent aftermarket calipers after its on the road. _________________ 2013 Dodge Durango R/T Hemi
1965 Ford Anglia 106e Estate (LHD)
1964 Ford Anglia 105E 1500 GT (Dad)
1980 Porsche 911 SC Targa (Uncle)
1971 MGB GT (V8 project) -SOLD 2016
2005 MINI Cooper S JCW - SOLD 2016 |
