Ok to use?
XL391
PostPosted: Tue Apr 23, 2013 2:16 am    Post subject: Ok to use? Reply with quote
Morning,
I'm going to clean all the contacts all over the car to try and reduce the electrical gremlin population within the Jag. My question is, is it ok to apply a small amount of copper grease between the two connections to prevent further deterioration?
Regards,
Will
1965 Sunbeam Tiger Mk1
1968 Triumph 1300
PostPosted: Tue Apr 23, 2013 11:12 pm    Post subject: Reply with quote
Not sure about coppergrease, but ordinary Vaseline works quite well to give some additional protection. It's not just for battery terminals, in fact it meets all sorts of difficulties Smile
Uncle Alec
PostPosted: Wed Apr 24, 2013 8:26 am    Post subject: Reply with quote
Copper grease? No! It does conduct electricity but is not efficient, so heat will build up and do more harm than good.
Invest in a tin of Switchlube from Maplins or the grease in the link below, which has similar properties but is longer lasting. Switchlube, Electrolube or similar leaves a residual coating on electrical contacts.
http://www.maplin.co.uk/contralube-770-connector-lubricant-346030
Kelsham
PostPosted: Wed Apr 24, 2013 9:55 am    Post subject: Reply with quote
In my last life as a service tech working on print machines we were supplied with small tubes of conductive grease. This was meant to be used on a sliding contact on a very high voltage circuit.
On one occasion I experienced problems where the charging of the drum it fed, was failing. I cleaned off the grese and normal service resumed.
I never trusted it again, and used only the minimum for lubrication afterwards.
The contacts need to be clean and tight, and anything you apply will be to keep moisture out.
Kels
PostPosted: Wed Apr 24, 2013 2:11 pm    Post subject: Reply with quote
I tend to go with the "dry" surface contact. Both parts should be clean and as smooth as possible.
We have oil and grease in our vehicles in order to keep two surfaces apart.
PostPosted: Wed Apr 24, 2013 6:29 pm    Post subject: Reply with quote
I used to be a mechanic in a workshop where we serviced commercial ride-on mowers. I borrowed some "skin-over" grease that was used on every electrical connection on Toro mowers and used it in a similar way on my Austin. 20 years on and all electrics are fine. It was black and dried hard. This also sounds useful but is different:
http://en.m.wikipedia.org/wiki/Silicone_grease
PostPosted: Thu Apr 25, 2013 8:11 am    Post subject: Reply with quote
I also use Contralube 770 on all exposed connections; the Lucas bullet connections especially offer very little protection against the elements.
XL391
PostPosted: Fri Apr 26, 2013 12:34 am    Post subject: Reply with quote
Thank you for your replies gents. Smile
Regards,
Will
1968 Triumph 1300
