Posted: Fri Apr 26, 2013 10:41 pm Post subject: Painting |
Obvious question maybe.
When painting over an existing colour, say a darker blue over a lighter blue, am I meant to undercoat it, or can I rub the existing colour down and put first coat of topcoat on, using the old colour which is similar as an undercoat?
In addition, if some area's have been greasy/oily, what is best to use to degrease it prior to paint?
Posted: Sat Apr 27, 2013 6:30 am Post subject: |
Hi Dave
Yes its ok to paint straight over existing paint as long as the paints are compatible, if they are not you will have to use a barrier coat, but if you are using 2K it seems to work over everything. De-grease everything with panel wipe (don't use thinners or other solvents as you can find it dissolves the paint and creates more work!), rub it down de-grease again and before you put paint on go over with a tack cloth.
I can sort you out with some panel wipe and tack cloths, have loads of both!
peppiB
Posted: Sat Apr 27, 2013 11:19 am Post subject: |
2K does not work over everything. Paint shop I used last year, having asked them to use bar coat and primer first, simply rubbed down the existing coach paint and sprayed 2K on top. There were many areas of reaction all over the body.
I have just finished sanding out those areas, giving the whole car 3 coats of bar coat (there were still reactions after only 1 coat) high build then normal primer and finally the top coat - which is still waiting for me to be well enough to flatten and mop (so far only managed 1 wing )
Panel wipe is the only way I have found to effectively remove all grease and wax |
Posted: Sat Apr 27, 2013 12:23 pm Post subject: |
I am to use a Coach Enamel over an ordinary gloss paint, as that you buy from Johnstones etc, is it an alkyd based paint? |
Posted: Sat Apr 27, 2013 1:03 pm Post subject: |
buzzy bee wrote: | I am to use a Coach Enamel over an ordinary gloss paint, as that you buy from Johnstones etc, is it an alkyd based paint? |
No idea if they are compatible ! you will just have to try a small test area, what are you painting? |
Posted: Sun Apr 28, 2013 1:26 am Post subject: |
Enamel over gloss should be fine, but as Dave says, try a small area to be sure. |
baconsdozen
Posted: Tue May 14, 2013 1:22 pm Post subject: |
Someone used Barcoat on my taxi during one of its myriad resprays at least.
Trying to touch up or respray and part of it turns into a nightmare as the paint used to do any repairs reacts with the stuff underneath and it bubbles or cracks sometimes days later.
I think I can either take it down to bare metal and start again (or rather bare metal and filler) or try some sort of enamel. _________________ Thirty years selling imperial hand tools for old machinery(Now happily retired). |
Posted: Tue May 14, 2013 6:25 pm Post subject: |
baconsdozen wrote: | Someone used Barcoat on my taxi during one of its myriad resprays at least.
I think I can either take it down to bare metal and start again (or rather bare metal and filler) or try some sort of enamel. |
There are a couple of things to watch with Barcoat; firstly any high points need to be dealt with first, otherwise there is a risk when flattening that the Barcoat gets removed or scored. Secondly Barcoat wont protect against moisture in the filler; if someone has filled a low spot and left it a week before its painted the filler could absorb moisture, the moisture will eventually get out in the form of micro blisters, weeks or months later..
baconsdozen
Posted: Thu May 30, 2013 1:21 pm Post subject: |
Thanks,I think thats what's happening,when rubbing down to repaint after a rust or dent repair the sanding removes the barcoat and the new paint then reacts. On the last repair I used a red oxide paint as a primer/undercoat and its held rust at bay (it brke through conventional primer quickly) and has not reacted with the paint underneath. _________________ Thirty years selling imperial hand tools for old machinery(Now happily retired). |
Posted: Wed Oct 09, 2013 4:23 pm Post subject: |
just reviving this topic and a question i need to ask.
when using cellulose, you read so many nightmares about the primer absorbing moisture prior to the topcoat and causing blisters.
so, a few questions please.
when using cellulose, how long can the primer be left safely without absorbing moisture (is a couple of days ok?)
when prepping between coats, do you rub each layer with wet n dry using water or do you use the paper dry?
some conflicting info out there hence my questions to those of you who have experience.
kev |
