Brake id
bsa500
PostPosted: Mon May 27, 2013 9:18 pm    Post subject: Brake id Reply with quote
Hi,
Some of you may have seen my post on the general section introducing my project. In a nutshell its prob 1932 SS cars chassis and front axle,maybe a Standard 10 sidevalve lump with twin SU's a of yet unidentified rear axle. The point of this post is to hopefully id the brakes so I can service the slave cylinders and find out what lining/shoes I need in the future. I have included some pictures.
Many thanks in advance Andy
Ashley
PostPosted: Tue May 28, 2013 3:16 pm    Post subject: Reply with quote
Why not send the slave cylinders for overhaul and stainless steel lining by Past Parts and just have the existing shoes relined.
PostPosted: Tue May 28, 2013 3:24 pm    Post subject: Reply with quote
As Ashley says, you can get any brake shoe re-lined so that's not an issue. Likewise re-sleeving the cylinders, or measuring the bores (if they're good enough) and ordering seals to fit, should see the cylinders sorted out.
PostPosted: Tue May 28, 2013 4:18 pm    Post subject: Reply with quote
Hi Andy,
I don't think they are Girling or Lockheed.
Like Ashley and Rick I was just going to suggest that you get them relined.
Try: http://www.chelseafrictions.co.uk/2.html
bsa500
PostPosted: Tue May 28, 2013 4:25 pm    Post subject: Reply with quote
Sorry for any confusion I fully intend to have them relined serviced etc,but thought the process would be easier if I knew the make. I can service the cylinders myself if I could buy the kit I also intend to replace the brake lines and master cylinder myself as well.
thanks for the replies I shall some time in the future check the rest for any sort of marks. Very Happy
bsa500
PostPosted: Tue May 28, 2013 9:31 pm    Post subject: Reply with quote
I have found out these brakes are from the Wolseley Hornet first used in 1932. The salve cylinder is a 1 inch bore,so anyone know where to get spares from?
bsa500
PostPosted: Tue May 28, 2013 9:32 pm    Post subject: Reply with quote
JohnDale
PostPosted: Thu May 30, 2013 4:23 pm    Post subject: Reply with quote
Hi Beeza, try Powertrack for seals, 01753 842680 or www.powertrackbrakes.co.uk
Always very helpful with lots of stock,cheers,JD.
1976 Ford Granada Ghia.
bsa500
PostPosted: Wed Jun 05, 2013 7:43 pm    Post subject: Reply with quote
Just a couple of pics of the rear cylinder,or whats left of it....
PostPosted: Fri Jun 21, 2013 7:01 pm    Post subject: Reply with quote
Bumping this up.
Curious as to the latest
