The Hazelcar
PostPosted: Wed Jun 19, 2013 1:30 pm    Post subject: The Hazelcar Reply with quote
While searching around for other things I stumbled across this interesting site, about a car I'd not heard of before. Worth a look if you like oddball, low-volume cars of the post-war era Smile
http://www.hazelcar.co.uk/index.htm
Riley Blue
PostPosted: Wed Jun 19, 2013 1:37 pm    Post subject: Reply with quote
How nutty is that...!
PostPosted: Thu Jun 20, 2013 9:13 am    Post subject: Reply with quote
It's quite confusing trying to work out how the drive is taken to the wheels. If I've interpreted the photos correctly then the gearbox is on the near side and drives a shaft in front of the engine via an encased chain but the rear axle is behind the engine so I assume that there is another chain on the off side that couples to the offside rear wheel. There isn't any obvious diff. so I guess the near side rear wheel is not driven.
