Did you ever invent something ?
PostPosted: Thu Jul 04, 2013 6:32 pm    Post subject: Did you ever invent something ? Reply with quote
Readng the BBC news, I came across this article.
http://www.bbc.co.uk/news/magazine-23179103
My inventing is somewhat limited, but over the years I have likely made all range of things to do a specific task.
1960's. Rewired the Mini with two flasher units, so I could have "Hazard Flashers" I ignored the out of sequence detail.
1960's. I cut approx 1/2 inch long pieces of rubber tube, removed the brake adjuster screws on the mini and refitted them via the piece of lubricated tube. They never seized again.
1960 - 70's Fastened strips of 1" wide elastic to the wall of the garage, with loops that would hold spanners, scewdrivers etc.
1970's used some large (5") scrap ball bearing assemblies (Thanks to the National Coal Board) to build 4 dollies that allowed me to push my cars sideways in the garage.
1960's. Tapped off some 1/4" copper pipe from the Mini's heater hose to warm the plastic washer bottle. It worked great in the summer !!
PostPosted: Thu Jul 04, 2013 7:25 pm    Post subject: Reply with quote
I have a couple of patents:
http://pminer.org/patent.do?m=viewPatent&id=3543588
http://pminer.org/patent.do?m=viewPatent&id=1386538
I never made any money from them but my employer did.
Peter Sad
PostPosted: Thu Jul 04, 2013 7:35 pm    Post subject: Reply with quote
Peter Sad
Crying or Very sad Does make one wonder about good old decent ethics.
I have to admit to being far less innovative and caring in my work, I retire in a few weeks anyway. But the experiment revealed that I was not treated any differently at 60% effort than for 100%+ effort.
But that is getting off topic and maybe not the best subject to pursue.
PostPosted: Fri Jul 05, 2013 11:06 am    Post subject: Reply with quote
'Invent' is probably not the term that I would use, but I am frequently problem solving in less than conventional fashion. I have previously posted a couple of my solutions- a modified clutch-shaft bearing on a Rover P4, making a replacement lamp for a 50+ year old movie projector. Yesterday, as an example, I needed a 8mm socket fitted to an electric drill in order to screw down corrugated roofing material. It is too far for me to run to the nearest hardware to buy the correct adapter, and anyway it was just for one job. I had a suitable socket with ¼" drive, so took an old ¼" drive screwdriver, sawed it in half and held the bottom end in the drill's chuck with the socket on the end. It worked perfectly. One day I will find a use for the handle end of that screwdriver!
PostPosted: Fri Jul 05, 2013 12:50 pm    Post subject: Reply with quote
Yesterday I made a trolley jack adaptor for removing the 354cc engine
from my Honda pickup from a piece of plywood and an old file handle,
worked a treat Cool
PostPosted: Fri Jul 05, 2013 2:23 pm    Post subject: Reply with quote
Rover Driver: "One day I will find a use for the handle end of that screwdriver!"
A short screwdriver ? Smile
PostPosted: Fri Jul 05, 2013 2:26 pm    Post subject: Reply with quote
My wife reakons i invent loads in my head! Not sure what she means tho ;0)
PostPosted: Fri Jul 05, 2013 3:23 pm    Post subject: Reply with quote
We were not put on this earth to understand what they mean
PostPosted: Fri Jul 05, 2013 7:15 pm    Post subject: Reply with quote
I remember making my own clutch alignment tool for a Sceptre using a dowel and loads of butterfly brown paper sticky tape.
V8 Nutter
PostPosted: Fri Jul 05, 2013 7:56 pm    Post subject: Reply with quote
Not an invention, but a suggestion. I was an apprentice at a company that made huge hydraulic machines for forming steel car bumpers. The company had a suggestion scheme where employees could win £25 for good suggestions. In the mid sixties Buick introduced plastic bumpers, I suggested to company looked into making moulding machines, because what Detroit does today others do tomorrow. I was told don't be stupid plastic bumpers will never catch on
