Leaf Spring hanger bolts seized
D4B
PostPosted: Tue Jul 02, 2013 8:46 pm    Post subject: Leaf Spring hanger bolts seized Reply with quote
Looking for some advice please (Honda TN7 pick up truck 1977)
1) having never removed a leaf spring from a vehicle before, am I correct in assuming that with the vehicle jacked up and supported on the chassis by axle stands (all weight off of wheels and suspension) the leaf springs can be unbolted removed, and then refitted without the need for struggling against spring tension?
2) Trying to remove the rear upper spring hanger bolts, but they have rusted solid into the metallastic bushes, so much so that you can feel the spanner springing back against the stretching rubber in the bush...
Any advice on how to crack these? Obviously they have been soaked in
Plusgas already but no go yet.....
Thanks Steve
PostPosted: Tue Jul 02, 2013 8:54 pm    Post subject: Reply with quote
Im assuming that as well as the stands under the chassis you have supported the axle? I usually use 2 more axle stands and a trolley jack to to this task. As for the bolts, if new ones are available then id cut them off and drift them through. If not then a large breaker bar may crack them? Make sure to apply a smear of copper grease when re-asembling to prevent these problems in future.
Kev
websnail
PostPosted: Tue Jul 02, 2013 8:58 pm    Post subject: Reply with quote
Only done it on my old Landrover.
Disk cutter to remove the pins as required.
If the springs are rusted and have spread, take care when cutting the U bolts as they go-with-a-bang Smile
PostPosted: Tue Jul 02, 2013 11:48 pm    Post subject: Reply with quote
Steve, I have done that job with my Austin. If you haven't already done I would take off the axle; the weight won't be helping you and then it should mean there is little or no tension in the spring. Although watch the hanger when it does move because there might be tension in that that could give whiplash.
It looks like you might have fiddle about with a hacksaw to cut the shackle bolts or maybe there is access for a fine cutting disc. I have tried everything including burning away the rubber (extinguisher at the ready) which might heat things enough to get the pin moving with a whack.
It's pretty unlikely that the inner sleeve of that elastic bush is going to let go of the bolt that passes through it judging by the corrosion you have shown elsewhere on the pickup. Good luck with it...it's got to come off eventually.
ka
PostPosted: Wed Jul 03, 2013 6:59 am    Post subject: Bushes Reply with quote
I can only echo the previous advice. ensure all is supported, and plan to sacrifice the metallastic bushes and bolts; then get the angle grinder ready!
KA
Better three than four.
D4B
PostPosted: Wed Jul 03, 2013 8:25 am    Post subject: Reply with quote
Wow, all great advice, so before I proceed I will check if the bushes are available and report back....
Thanks
D4B
PostPosted: Mon Sep 16, 2013 6:58 pm    Post subject: Reply with quote
Well I ended up buying a pair of new rear shackle bushes from CMS in
the Netherlands, as there was no way the rusted ones were going to let go!!
Today I cut them off using a thin 4.5" cutting disc on an angle grinder, so
now I can crack on with cleaning up the whole underside of the truck.
Cool
PostPosted: Thu Sep 19, 2013 6:40 pm    Post subject: Reply with quote
Assuming you remove the shackle pins and bushes O.K. (some good advice above).
One thing often overlooked is that tightening shackle pins passing through metalastic bushes (usually called silent-bloc bushes in my day) with the suspension relaxed and "hanging" will usually wind-up the said bushes and trap them under torsional strain so that they fail prematurely, as well as often "jacking up" that end of the vehicle. Looking as if the springs are too strong!
Tighten everything with the vehicle STOOD ON ITS WHEELS. NOT with the suspension HANGING!
This is a safer way of tightening nuts and bolts in any suspension re-build.
Jim
D4B
PostPosted: Thu Sep 19, 2013 9:39 pm    Post subject: Reply with quote
Thanks Jim, makes sense to me, I will have to loosely reassemble
the springs, hanger and axle while it is still laying on it's side then
once it's back on it's wheels I can make sure it's all aligned and tighten
up as you suggest.
Mind you that's not until after the whole underside of the truck is cleaned
up derusted and waxoyl shutzed Cool
Steve
PostPosted: Thu Sep 19, 2013 9:56 pm    Post subject: Reply with quote
Steve, I should have added "bounce the vehicle on its suspension if possible to settle everything into working position - then tighten up"
Jim,
D4B
PostPosted: Fri Sep 20, 2013 8:27 am    Post subject: Reply with quote
Ok will do cheers
PostPosted: Fri Sep 20, 2013 5:45 pm    Post subject: Reply with quote
Ah but, won't working position on the pickup be when a heavy load such as two bags of flour and a bag of candy-floss is placed on the flatbed? Laughing
D4B
PostPosted: Fri Sep 20, 2013 6:47 pm    Post subject: Reply with quote
You just let me know when you want that Fiat 500 moving Laughing Laughing Laughing
D4B
PostPosted: Mon Sep 30, 2013 4:24 pm    Post subject: Reply with quote
It's all going back together now ~ thanks for all your help
BigJohn
PostPosted: Mon Sep 30, 2013 5:23 pm    Post subject: Reply with quote
Steve, now make a big paper sign to stick to the steering wheel, SHACKLES LOOSE.
because when your on your wheels excitement will take over, and you'll be off! Laughing
Unless you want Prelude style rear wheel steering of course.
