1970's Labcraft 12v lights
Peter H
PostPosted: Thu Sep 26, 2013 9:55 am    Post subject: 1970's Labcraft 12v lights Reply with quote
Hi, I'm restoring a 1978 Carlight Cassetta and the covers on the Labcraft 12v ceiling light covers have become discoloured. I have tried bleaching them and although there has been a little improvement I an not happy with the result. I contacted Labcraft but the light is no longer available. I was hoping someone may have a couple of spares or an idea how the plastic can be lightened. The lights work fine and I don't want to change them for modern ones. C:\Users\Janet\Pictures\carlight light\IMG_3348.JPGThanks.
Dalek63
PostPosted: Thu Sep 26, 2013 10:46 am    Post subject: Reply with quote
I found this on the net, hope it might help
http://www.howtocleanstuff.net/how-to-whiten-yellowed-plastic/
christine lowery
PostPosted: Thu Sep 26, 2013 12:08 pm    Post subject: Reply with quote
hi if they are the long rounded lab craft cl 13 type we have beem replacing the diffusers with opaque lexon or similar and converting them to led at the same time
christine Cool
Peter H
PostPosted: Fri Sep 27, 2013 10:13 am    Post subject: Reply with quote
Yes they are. I tried to download a pic but failed. Where do you buy it from ?
Thanks
christine lowery
PostPosted: Fri Sep 27, 2013 1:11 pm    Post subject: Reply with quote
try a shop front fitter the thin size is hard to find you need 1mm or thinner in opal or opaque
you can add the stripes with car piping if you need to
as i said i rip out the guts and fill the inside with led on a roll to give a better light for a 10th of the electric if you use the van withuot hook up
chris
Smile
PostPosted: Fri Sep 27, 2013 2:31 pm    Post subject: Reply with quote
on ebay? ;
http://www.ebay.co.uk/sch/i.html?_trksid=p2050601.m570.l1313.TR0.TRC0.Xlexan&_nkw=lexan&_sacat=0&_from=R40
Peter H
PostPosted: Fri Oct 04, 2013 7:53 am    Post subject: Reply with quote
Thanks for your help. I have now managed to find the lexan 0.75mm in opal. I'll also take your advice and change them to led.
david_rachel
PostPosted: Thu Oct 10, 2013 1:22 pm    Post subject: Reply with quote
Hello Peter,
I found the best way to make the chrome effect stripes is to buy a sheet of silver paper/thin card. Attach this to some very thin double sided tape and then use a paper guillotine to cut strips of the desired length. I used a length of masking tape on the light covers to act as a guide line against which to lay my narrow strips so that they didn't end up at some silly angle! Also, make the strips long enough to fold over a good 1/4" inside the lamp cover...
David Rachel
1978 Carlight Casetta
1995 Lada Riva 1.5 Est Red
Margo
PostPosted: Fri Oct 11, 2013 8:57 am    Post subject: Reply with quote
Or you could simply use car pinstripe off the roll - comes in chrome and gold as well an an infinate range of colours Very Happy
david_rachel
PostPosted: Fri Oct 11, 2013 1:00 pm    Post subject: Reply with quote
....it all depends on how much of an anorak you are regarding the need to replicate the original trim width - I'm a real anorak! Very Happy
David Rachel
Crooked_Caravan
PostPosted: Fri Oct 18, 2013 9:11 pm    Post subject: Reply with quote
I'm told toothpaste is really good for cleaning lights – might be worth a try?
