Morganrsn
Posted: Wed Oct 02, 2013 2:50 pm Post subject: Morris 8 Series 1 1937 - Jacking points? |
I am changing the brakes on my Morris 8, the front is on axle stands but I am not sure where the back jacking point is? Do I put the jack where the rear leaf springs are? or could I jack it on the bottom of the diff?
Any help much appreciated. Thanks |
Morganrsn
Posted: Wed Oct 02, 2013 3:19 pm Post subject: |
Thanks I will go and give it a go now. |
hunsta
Joined: 09 Sep 2013 Posts: 92 Location: Gympie Qld Australia
Posted: Thu Oct 03, 2013 8:16 am Post subject: |
I always found that putting any car on jack stands front and rear, I put the rear up first. Placing the stands as close to the springs on the axle housing. Then the front. This allows the car to pivot on the axle housing and not push the stands backwards as you raise the front. _________________ I really am a nice guy. Just ask anyone that hasn't met me. |
welder
Joined: 26 Nov 2007 Posts: 265 Location: North Warwickshire
Posted: Thu Oct 03, 2013 10:28 pm Post subject: Re: Morris 8 Series 1 1937 - Jacking points? |
Morganrsn wrote: | I am changing the brakes on my Morris 8, the front is on axle stands but I am not sure where the back jacking point is? Do I put the jack where the rear leaf springs are? or could I jack it on the bottom of the diff?
HI Morganrsn, welcome to this cracking forum.
I, too, own a 1937 Series 1 and can tell you that there are no jacking points as such. What you suggest/propose about putting your jack beneath the diff housing is exactly what I do, assuming, of course, that you're talking about a trolley jack.
If not, go out and buy one with a fairly large "contact" pad, put a cloth over said pad and jack up the back of the car, then insert suitable axle stands. Sorted.
Ian |
goneps
Posted: Wed Dec 25, 2013 11:38 pm Post subject: |
Coming a bit late to this thread, but here goes.
When jacking up with a trolley jack, the jack will roll as the car is raised, to follow the arc of the jack's arm, so no fear of its pushing over the axle stands at the other end.
For jacking under the diff., to accommodate the protruding drain plug, drill a 1/2" hole in a 1" thick short length of timber and place on the jack's pad so that the plug goes into the hole. This is by far the best and safest way to proceed, and will avoid damage to the plug and diff housing. The plug's thread was never intended to take the entire weight of the back end of the car!
Richard |
