SplodgesDad
Joined: 02 Mar 2013 Posts: 52 Location: Wendron Cornwall
Posted: Sat Mar 23, 2013 10:29 am Post subject: Ford V8 Pilot - 1949 |
Well here she is, Amelia.
Found by chance and fell for her straight away.
Greg
Posted: Sat Mar 23, 2013 10:36 am Post subject: |
Hi Gavin, that is I lovely car you have there, superb!
I do like an old Ford!
Good luck with it,
All the best,
Greg |
JohnDale
Posted: Sun Mar 24, 2013 12:59 pm Post subject: |
Absolutely beautiful,lucky man,cheers,JD. _________________ 1958 Ford Zephyr Mk2 Convertible
1976 Ford Granada Ghia. |
SplodgesDad
Posted: Sun Mar 24, 2013 2:44 pm Post subject: |
| Thanks for the comments guys, had to scrape a lot of pennies together to buy her though........... |
V8 Nutter
Posted: Mon Mar 25, 2013 8:31 pm Post subject: |
| Lovely car. They can be difficult at times, but when they are right they're great. |
JohnDale
Posted: Wed Mar 27, 2013 1:23 pm Post subject: |
| SplodgesDad wrote: | | Thanks for the comments guys, had to scrape a lot of pennies together to buy her though........... |
Hi, I'm a member of the Pre67 Ford O.C. here in Scotland. Would you mind if I put a copy of the pic of your Pilot on our forum? Thanks,JD. _________________ 1958 Ford Zephyr Mk2 Convertible
SplodgesDad
Posted: Wed Mar 27, 2013 2:14 pm Post subject: |
JD
More than happy to do that.
Will pm you with image details if you need them. |
SplodgesDad
Posted: Tue Apr 02, 2013 10:35 pm Post subject: |
Can anyone recommend a decent electronic ignition system to fit a twin point flathead V8 distributor?
The points on mine have given up the ghost and I really don't feel like changing them every few months, When you see where the dizzy is on these, you'll understand why!
I've checked out Accuspark and they only seem to do the single point set-up.
Thanks
Gavin |
Landy Des
V8 Nutter
Posted: Wed Apr 03, 2013 8:27 pm Post subject: |
I think Pertronics should do something.
If you are having recurring point problems make sure the ballast resistor has not been bypassed, it should be on the bulkhead under the dash. I am probably telling you something you already know, but the easiest way to set the points is take the distributor out. 3 bolts and the vacuum pipe, 10minute job. Putting it back is no problem because it is driven by an offset key. Point gap is really critical for good performance. Ford dealers used to use a fixture for setting the dwell with the distributor off the engine |
Kelsham
Posted: Thu Apr 04, 2013 8:12 am Post subject: |
Be interesting to see how you set the system up with electronic ignition, I believe it is difficult enough with single points replacement units.
It's strange how values change, I recall a friend who had a pilot in the 1960s He couldn't give it away.
Too thirsty, and low wages didn't help.
I hope the valves don't need attention, the Ford system is very awkward.
I worked on a Jensen a few years ago, Ford sidevalve V8, I still wince at the memory.
Regards Kels. |
SplodgesDad
Posted: Sat Apr 06, 2013 4:30 pm Post subject: |
Thanks for your help guys, one electronic ignition kit ordered from Jolley Engineering. Not cheap but the only ones able to supply a system.
A note for anyone else with an old flathead V8, there are not many companies around that cater for the twin points system.
Accuspark and a UK Pertronix supplier were unable to help.
Now to find a decent exhaust supplier who can sort out some religious downpipes!  |
Landy Des
Posted: Sat Apr 06, 2013 5:25 pm Post subject: |
You're one step ahead of me.. if you find a decent supplier for the exhaust I would be grateful for the info. I'm not having a lot of luck myself.
Good news on the ignition kit, I was put on to Jolley Engineering by a friend with a flathead but have to save my pennies for a bit (or sell a car LOL) |
SplodgesDad
Posted: Sat Apr 06, 2013 5:33 pm Post subject: |
Hi Des
Where a outs are you?
I've seen a couple of websites advertising full stainless systems but they really aren't cheap! |
