Mystery straight six engine block
PostPosted: Wed Oct 09, 2013 2:47 pm    Post subject: Mystery straight six engine block Reply with quote
Does anyone recognise this?
The owners don't know what it's from. Someone suggested Jaguar to them, but if the "3L" on the side is its capacity, ie 3 Litres, it seems unlikely.....?
All thoughts welcome Smile
Ellis
PostPosted: Wed Oct 09, 2013 3:58 pm    Post subject: Reply with quote
Looking at the word "Bilchrome" on the casting, Bilchrome was a Sheffield based cutlery manufacturer which also at one time, 1950s I think made castings for the car industry.
There is a reference on here from 2010, before I joined, naming Triumph and Massey Ferguson.
Although the block does not at first look like a Jaguar one but it could be from an early 2.4 litre Mark One. The maximum bore would have been 3L in the same way a Jaguar 3.4 has 3.5L stamped on it's block.
One more thing, the horn shown on the first photo is of the type used in 1950s and 1960s Jaguars - as one of a pair.
Starting Handle Expert
1964 Jaguar Mark 2 3.4 litre
1962 Land Rover Series 2a 88"
2002 BMW M3 E46 Cabriolet
PostPosted: Wed Oct 09, 2013 6:07 pm    Post subject: Reply with quote
Re Bilchrome, a FB user is suggesting a shortlist of Austin (A70?), Massey-Ferguson, Land-Rover & Perkins.
PostPosted: Wed Oct 09, 2013 6:34 pm    Post subject: Reply with quote
It's not an XK block and this one has push rod holes and a side camshaft. It's not pre-XK either. I think you can rule out Jaguar.
Austin A70 is a four cylinder job. From the length of the con rods it must be a fairly short stroke engine so quite modern.
I think it's Humber Super Snipe. Sorry, couldn't find a good web image but I have a drawing that fits your photos.
Churchill Johnson
PostPosted: Wed Oct 09, 2013 9:42 pm    Post subject: Reply with quote
Tell me the piston length and bore size also if piston's are marked oversize and check inside the piston's for any number's and i will look in my Wellworthy book.
PostPosted: Thu Oct 10, 2013 11:08 am    Post subject: Reply with quote
I thought the Super Snipe had a 4 litre engine?
BTW there is a lovely 50s Super Snipe on Ebay right now.
http://www.ebay.co.uk/itm/121190644298?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1438.l2649
JohnDale
PostPosted: Thu Oct 10, 2013 11:32 am    Post subject: Reply with quote
Humbers were all side valves until '53 when the Super Snipe was the first with an OHV engine which was a 4 ltr Commer truck engine. 1960 on Super Snipe ll/lll/lV had a 2965cc ohv 6 cyl engine. Cheers,JD.
1976 Ford Granada Ghia.
