Gjneves
Posted: Fri Nov 29, 2013 1:32 am Post subject: |
Rick wrote: | If it is like the Austin A40 Devon I used to own (1949), there is a small nut on the bottom of the steering box which needs removing before the switch, horn button, and the tube down which the wiring passes, can be pulled up and out of the column. Maybe the Morris is similar?
RJ |
Thanks a lot Rick, its like you said!
I already fix the problm.
Thank you.
Gonçalo Neves |
Gjneves
Posted: Mon Dec 02, 2013 5:29 pm Post subject: starter engine |
Hy guys!
I have another problm um my morris 8
Before repair all electric system and radiator now the starter engine rotates but the bendix don't clutch on engine wheel. I change the batery but the problm persist.
Any idess?
Gonçalo Neves |
Posted: Mon Dec 02, 2013 5:37 pm Post subject: Re: starter engine |
Gjneves wrote: | Hy guys!
Any idess?
Gonçalo Neves |
- Is there any dirt on the shaft, that the bendix slides along? Maybe it is sticking on the shaft, try hitting the starter motor with a block of wood (not too hard!)
- Are all the electrical connections tight and clean? Maybe the starter is not spinning enough.
Gjneves
Posted: Tue Dec 03, 2013 12:18 am Post subject: Re: starter engine |
Rick wrote: | Gjneves wrote: | Hy guys!
Any idess?
Gonçalo Neves |
RJ |
I try hittinhg on starter motor with a hammer,not too hard! But still not working
I think the connections are ok because a few times ago its working. I push the bottom,the engine roll at first,second and thirth time, but at the fourth time bendix clutch on engine wheel. However now just rotate.
Gonçalo Neves |
norustplease
Posted: Tue Dec 03, 2013 10:39 pm Post subject: |
The starter will have to come off and be inspected. If there are no missing teeth on either pinion or flywheel, then give the pinion and shaft a good clean with white spirit or paraffin. Then refit and give it another try. _________________ 1953 Citroen Traction
1964 Volvo PV544
1957 Austin A55 Mk 1
Boring Tucson SUV |
Gjneves
Posted: Thu Dec 05, 2013 4:16 pm Post subject: |
norustplease wrote: | The starter will have to come off and be inspected. If there are no missing teeth on either pinion or flywheel, then give the pinion and shaft a good clean with white spirit or paraffin. Then refit and give it another try. |
Well, I pull it off and dismount the interior starter motor.
What do you think about the conditon?
Gonçalo Neves |
Posted: Fri Dec 06, 2013 8:52 am Post subject: |
Its the free moment of the starter pinion that's important, it can just be seen on the top photo, and the shaft looks a little grubby or rusty? how freely does it slide up and down the shaft?
