Need help on identifying a Zenith carb.
KartoffelChips
PostPosted: Fri Dec 20, 2013 10:16 pm    Post subject: Need help on identifying a Zenith carb. Reply with quote
Hi all,
New to the forum - and need some help on identifying a Zenith carburettor..
I'll introduce myself a bit more thoroughly in another thread - but basically I'm dealing with classic Volvos (the 120 series mainly) and the early ones also use the Zenith carb. - I've had this one lying around for more than 10 years - it's NOS - but I haven't been able to identify it - it's not for the Volvos although it's almost the same Volvo used.
Can anyone help me out?
TIA.
/Soren, Copenhagen, Denmark
1964 Volvo 221/1964 Volvo 222/1964 Volvo 131
PostPosted: Fri Dec 20, 2013 10:36 pm    Post subject: Reply with quote
It says on your carb VN
This is the model of carb.
If you can tell me the diameter of the choke tube I may be able to tell you what it fits. They made the VN carb in these choke tube sizes according to my Zenith book: 30, 32, 33, 34, 36, 37, 42mm.
Hope this helps
PostPosted: Fri Dec 20, 2013 10:43 pm    Post subject: Reply with quote
It would appear to be a Type VN, but what size is it? The 36VN was used on early Volvos, but also on International Harvester tractors! Smaller sizes, 30 and 34, were fitted to Vauxhall Velox and Ford Consul of the mid-1950s...
I would guess there will be quite a wide variety of applications for the basic body, but fixtures and fittings will differ; I think the C-number on the inlet casting is the contract number which will positively identify it, but I don't have the records to confirm it, sorry. I don't think all applications have the additional casting on the bottom of the carb, so that might help identification.
Edit: D4B beat me to it!
KartoffelChips
PostPosted: Fri Dec 20, 2013 10:50 pm    Post subject: Reply with quote
Thanks! Great - well, I should have specified that I am aware of that it is a VN model Zenith carb. - I was more looking for an answer that could direct me towards where it's used - car/make/engine etc.
On top of the reservoir it's stamped:
C 1645 0456
Diameter of hole that goes against manifold, apr. 36 milimeters (I don't have 100% accurate figure here, sorry).
PostPosted: Sat Dec 21, 2013 11:33 am    Post subject: Reply with quote
If it is a 36VN there are many applications, one of which is
Volvo B18A 1961 - 1966
I will expand on that when I have more time Wink
Steve
JohnDale
PostPosted: Sun Dec 22, 2013 12:11 pm    Post subject: Reply with quote
It appears to be a governor type which would point towards a commercial rather than a car,cheers,JD.
1976 Ford Granada Ghia.
PostPosted: Sun Dec 22, 2013 10:48 pm    Post subject: Reply with quote
36VN is also listed to fit:
Austin 2,3,4 ton F C Truck 1962 - 1968
BMC as above but 1960 - 1970
Bedford CA Van 1500, 1600 1956 - 1964
Ford Zephyr 4, MK111 1962 - 1965
and can be used as replacement on:
Ford Cortina MK11 1600cc cross flow 1967 - 1970
Ford Capri 1600cc cross flow 1968 - 1970
Ford Cortina MK11 1300cc cross flow 1967 - 1970
Ford Capri 1300cc cross flow 1968 - 1970
Ford Escort 1300cc 1968 - 1970
Source Zenith Carburetters Servicing Function Testing booklet 1972
michael1703
PostPosted: Sat Dec 28, 2013 12:24 am    Post subject: Reply with quote
Could be for a generator,I've seen ford 204e/211e engines used for generator plants
