Wanted to buy. Kingpin + bush set for 48 Morris 8 E series
hunsta
PostPosted: Sat Oct 12, 2013 6:10 am    Post subject: Wanted to buy. Kingpin + bush set for 48 Morris 8 E series Reply with quote
Gday Im looking for a new set of king pins and bushes for my 1948 Morris 8 E series. Im having trouble locating anywhere to buy a set. Im in Australia, but happy to pay shipping costs what ever they may be. If not I would appreciate any links to some where to buy them.
Craig
I really am a nice guy. Just ask anyone that hasn't met me.
PostPosted: Sat Oct 12, 2013 8:49 am    Post subject: Reply with quote
Hi Craig
The Morris Register spares department stock them, and ship world wide. They do come up on ebay now and again, failing that they are quite simple to make; all you need is some 5/8" ground steel (often called shafting rod) and there are some off the shelf oilite bushes that are the correct size.
The shafting needs a tapping in the top, and a flat ground about half way down (can be ground by hand) the cotter pins may need replacing and the thrust washers will need to be made to fit. I made some for my Z van last year, it took about 30 mins per side to make the pin. I used an old Series E gearbox lay shaft as it's also 5/8"!!
hunsta
PostPosted: Sat Oct 19, 2013 6:11 am    Post subject: Reply with quote
Kingpin kit sorted. Very Happy
Rosco663
PostPosted: Tue Jan 14, 2014 10:24 am    Post subject: Reply with quote
Gidday Craig,
Where did you end up getting your king pin kits from? I bought a pair off Fleabay but they are the wrong size. Much larger than required.
cheers
Rosco
hunsta
PostPosted: Tue Jan 14, 2014 9:57 pm    Post subject: Reply with quote
Mate I tried so many enquiries and I ended up going to a Repco and they tracked down a set out of Vic. Ill try and find out who they got it from. Was a whole NOS set with felt dust covers end caps. The lot.
Rosco663
PostPosted: Tue Jan 14, 2014 11:36 pm    Post subject: Reply with quote
Exellent Craig Very Happy
If you could do that for me that would be great in the meantime I will try my local Repco and see what comes of it. I will keep you posted with progress.
My old king pins took just on 2-1/2 Tons to press out and the lower ends of both are pretty worn. How much vertical travel do yours show? I am just wondering if i need to shim up the thrust washer.
Rosco
hunsta
PostPosted: Wed Jan 15, 2014 1:09 am    Post subject: Reply with quote
No worries mate. Mine took nearly 10 ton on our old 35 ton press at work.
As for wear I had just under 1mm wear either side and ground down my old thrust washers and fitted them to the tops . With the new ones to the bottom.. This was a time consuming process but got firm with no movement. But not stiff
hunsta
PostPosted: Wed Jan 15, 2014 8:29 am    Post subject: Reply with quote
OK. I Went to my local REPCO this arvo, and although they remembered the sale, they weren't quite sure where they actually got them from . However if I take my invoice into them they said they could work it out from there.
However they did say to give you the part number and if you go to a REPCO near you they should be able to track a set down.
Product name: Genuine Glen Part
Part number: KX12
for: Morris 8-40 1935-48
Hope that helps mate. If no joy I`ll take my invoice in and have them track to dealer.
Craig
Rosco663
PostPosted: Wed Jan 15, 2014 9:52 am    Post subject: Reply with quote
Thanks for that Craig - I will pop into Repco tomorrow and give them the numbers and see what comes of it. I will let you know how I get on Wink What is the ball park figure for two sets?
Rosco
hunsta
PostPosted: Wed Jan 15, 2014 10:11 am    Post subject: Reply with quote
My set cost me $113.30 plus $16.00 freight as it had to come from Vic.
Rosco663
PostPosted: Thu Jan 16, 2014 2:47 am    Post subject: Reply with quote
Wow- just got back from Repco and was told nil in stock Ozzy wide and that they would need to place the order with manufacturing and was then quoted $156 plus freight Shocked
I think I will see about getting my hands on some 5/8" ground rod as per UK Dave's suggestion - I have sourced and priced the bushes already. Once I get all the pricing sorted I will make a decision either way.
Unfortunately it is off to work on Saturday for a month so everything will be on hold until my return. And being a delightful 46 degrees here today the shed is like an oven and is telling me to stay indoors in the air-conditioning.
More on this subject L8R.
Rosco
