e83w brakes
rabbito
PostPosted: Sat Feb 22, 2014 11:06 am    Post subject: e83w brakes Reply with quote
Come on buzzy bee you must be able to help with the return spring place meant has the is slowing do the project
help
rabbito
PostPosted: Sat Feb 22, 2014 12:39 pm    Post subject: Reply with quote
Does it not show things in the factory manual or parts book?
rabbito
PostPosted: Sat Feb 22, 2014 1:14 pm    Post subject: brakes Reply with quote
yes Rick it does show a spring coming from the back of the compression tube & going to the front cross shaft lever but the chassis cross member seems to be in the way
rabbito
PostPosted: Sat Feb 22, 2014 11:00 pm    Post subject: Reply with quote
Only just seen the Thread, you sorted it?
I will try to get some pics underneath mine for you.
rabbito
PostPosted: Sun Feb 23, 2014 12:49 pm    Post subject: Reply with quote
Thanks Dave that would be great [ is it the compression tube spring that is to do the return of the pedal ? ]
thanks
rabbito
