Can you help identify the vehicle these parts are from pls
nadene8389
PostPosted: Wed Feb 12, 2014 3:10 pm    Post subject: Can you help identify the vehicle these parts are from pls Reply with quote
Can anyone help me identify what these parts are off please?
[img][/img]
PostPosted: Wed Feb 12, 2014 3:18 pm    Post subject: Reply with quote
My first guess was Ford Model Y, but the no. of vents is incorrect for one thing (albeit they're in the correct position).
Morris 8 Series 1 is a possibility, that has 7 vents towards the rear of the side panels.
alanb
PostPosted: Wed Feb 12, 2014 6:58 pm    Post subject: Reply with quote
Looks like Morris 8, pre series, series 1, series 2. To me
old tourer
Morris 8 two seater
PostPosted: Wed Feb 12, 2014 7:38 pm    Post subject: Reply with quote
I'd agree with a Morris 8, and the bonnet catch is in the right place in relation to the vents.
Rosco663
PostPosted: Thu Feb 13, 2014 2:29 am    Post subject: Reply with quote
They certainly do look like Morris 8 bonnet leaves - but they are certainly different to my Series 1.
Where the two top sections come together, there are interlocking hinge sections - through which passes the brass hinge pin. Per the photo itwould appear that as these two sections come together the hinge would take on a full form with no gaps.
On mine there is also a 'rain gutter' as part of this assembly which hangs, below the hinged section, in the engine bay that directs water away from the top of the engine. This gutter is also held in place by the brass hinge pin - as such the second hinge 'loop' is missing from the top bonnet hinge at both ends, as it is replaced with the hinge loop on the 'rain gutter'.
This may be an Australian modification or possibly that the bonnet is from a Pre-Series or early Series 1. Unfortunately mine is 8500 odd kms away so can't post a photo right now Embarassed
Rosco
nadene8389
PostPosted: Thu Feb 13, 2014 2:30 am    Post subject: Reply with quote
Thanks all that's really helpful. Much appreciated
Rosco663
PostPosted: Thu Feb 13, 2014 2:38 am    Post subject: Reply with quote
BTW welcome to the forum Nadene Cool
Rosco
goneps
PostPosted: Thu Feb 13, 2014 3:54 am    Post subject: Reply with quote
The example shown would be from a very early 35 (pre-Series) model. Early cars did not have the drip channel, and unsurprisingly it was found in service that this caused ignition problems in wet weather (not exactly an unusual occurrence in Britain).
As far as I know the channel was added retrospectively. Certainly the Series I Parts List makes no mention of earlier parts, but no doubt a '35 Parts List would show different numbers. A similar case arose recently on the Morris Register (GB) forum in respect of other items superseded by a better design, the earlier parts being listed in the '35 Parts List but excluded from the Series I List. It's possible that the parts shown were discarded when the car's bonnet was replaced with the later improved design.
Richard
