Removing broken studs
PostPosted: Mon Feb 17, 2014 12:50 am    Post subject: Removing broken studs Reply with quote
I found this on the AACA forum and thought it might be of interest:-
http://modeltengine.com/brokenheadstud.htm
Art
PostPosted: Mon Feb 17, 2014 7:24 am    Post subject: Reply with quote
Or just weld a nut straight to it, welding down the inside to the top of the stud. Smile
Or get the drills out. Dormer Easy outs, the way forward, but don't buy cheap ones! Snap cheap easy outs off and you have more trouble on your hands.
PostPosted: Mon Feb 17, 2014 8:40 am    Post subject: Re: Removing broken studs Reply with quote
Art
That's genius and certainly worth a try.
PostPosted: Mon Feb 17, 2014 9:58 pm    Post subject: Reply with quote
Upon removing studs that had been in my engine for 90 years, one after another snapped off, bearing in mind they had been caulking in too, to seal them from the 200 pound pressure. I wound the nut back on, and welded it on, and not one snapped.
The heat locally on the stud is the key, doing it with the oxy did nothing to help.
