Ellis
Joined: 07 Mar 2011 Posts: 1382 Location: Betws y Coed, North Wales
Posted: Mon Mar 30, 2015 9:59 pm Post subject: Halogen bulb headlamp conversions. |
I'm interested in converting the old Lucas sealed beam headlamps on my Land Rover 2a to a halogen bulb headlamp conversion.
Have any of you done this and is the conversion worthwhile?
My 2a has an alternator rather than a dynamo.
Thank you. _________________ Starting Handle Expert
1964 Jaguar Mark 2 3.4 litre
1962 Land Rover Series 2a 88"
2002 BMW M3 E46 Cabriolet |
Posted: Tue Mar 31, 2015 8:35 am Post subject: |
I did it on my Lightweight, quite easy using the conversion kits from the likes of Craddocks etc.
I used a new upgraded loom for the lighting side which included relays etc.
Wasnt much work and quite cheap at the time but that figure has probably gone up a touch.
Totally worth while if you use the landy in the dark though as you can actually see whats in front of you!
kev |
Joined: 26 Jan 2012 Posts: 1740 Location: Above the snow line in old Monmouthshire
Posted: Tue Mar 31, 2015 8:47 am Post subject: |
I've done this on several vehicles over the years and it's well worth the small trouble and expense. It does annoy me though when I see the people who retail the conversions, and other self proclaimed experts, tell anyone who cares to listen that they need to fit an alternator conversion as well - this is nonsense. I've run my Herald for years on the original C40 dynamo, driven many many miles in the dark with heater fan, wipers and radio on as well as the lights - and the only problem I ever had with charging was down to sticking brushes in the dynamo. |
Posted: Tue Mar 31, 2015 8:55 am Post subject: |
Ditto
My MGA has the conversion, I replaced the whole unit including the lens, there may be benefit to use a different lens and reflector to suit the bulb focus? Optics not so thing I know much about !
You can get 7" LED headlamp units, they are very expensive, but if they perform anything like the LED headlamps on my modern , worth a look.
Ellis
Posted: Tue Mar 31, 2015 10:57 am Post subject: |
Thank you gentlemen! _________________ Starting Handle Expert
ka
![](images/avatars/128680028450bc5c3fcdfcd.jpg)
Posted: Wed Apr 01, 2015 7:50 am Post subject: |
Yes, I also swapped the "Dark Lords' sealed beams to H4. Easier than you would think, main wiring alteration was the sidelight, with different connectors.
I also chose to relay them in, as a matter of good practice. _________________ KA
Better three than four. |
alanb
TFM150K
Posted: Wed Apr 01, 2015 10:13 am Post subject: |
Please excuse my ignorance, ka, but where do you fit the relays? |
ka
Posted: Wed Apr 01, 2015 8:05 pm Post subject: |
Choice of many options, I am sure there are electricians out there who know better than I but; I use two relays one for dip, one for main. Provide a fused live feed from the battery to the relays. Use the dip wire from the headlight connection to the switch side of one of the relays, then the 'on' feed to the headlights from this relay for dip, duplicate the wiring to the main beam relay, main beam wire to the switch side of the other relay, 'on' side to main beam on the headlights.
I am sure someone can explain it better than I, any offers? _________________ KA
