rabbito
Joined: 21 Jan 2014 Posts: 15 Location: victoria australia
Posted: Thu Feb 20, 2014 10:15 am Post subject: fORD 10/10 E83W BRAKES |
I have redone all the brake shoes & drums & all moving parts repaired or replace .BUT one part that was not on my project was the return spring .in the manual it shows it to be coming of the back of the compression tube & going to the front cross shaft lever . but the chassis cross member seems to be in the way CAN any one suggest were I should put a return spring
THANKS rabbito |
