Distributor
1stpop
PostPosted: Fri May 02, 2014 7:30 pm    Post subject: Distributor Reply with quote
Can anyone point me in the direction of a reliable distributor supplier?
The hand book for my Hillman Minx series lllb says I need a Lucas DM4P2
any suggestions would be greatly appreciated - the original is a wreck - not even servicable
PostPosted: Fri May 02, 2014 9:27 pm    Post subject: Reply with quote
why dont you speak with an electronic ignition expert, good time to upgrade?
Kev
PostPosted: Sat May 03, 2014 6:45 am    Post subject: Reply with quote
Have you tried the Distributor Doctor - he may be able to suggest an alternative if he cannot fix it
Rover P2
Morris Mini Traveller Mk2
PostPosted: Sat May 03, 2014 9:25 am    Post subject: Re: Distributor Reply with quote
Are you sure it's not a Lucas DM2P4? If so a very common unit fitted to loads of vehicles.
PS
Just looked it up, it is a DM2P4 Lucas part number 40492A/B Smile
1stpop
PostPosted: Wed May 07, 2014 12:00 am    Post subject: Reply with quote
thanks it is a DM2P4 - and the cause of all my problems!!!!!
pmarshal
PostPosted: Thu May 22, 2014 9:50 am    Post subject: Reply with quote
Have you thought of going electronic, these are the affordable end of the market: -
http://www.accuspark.co.uk/distributors.html
1stpop
PostPosted: Sat Jun 14, 2014 1:54 pm    Post subject: distributor Reply with quote
Sent it off in May - just found out it will take 8/9 weeks.
Any suggestions where I can get a replacement? going to miss all the local shows!!
Is there an alternative to the DM2p4?
PostPosted: Sat Jun 14, 2014 2:39 pm    Post subject: Reply with quote
had the same problem a week or so ago
speak with accuspark
http://www.accuspark.co.uk/index.html
They list one suitable for the minx.
I fitted one of their distributors a couple of weeks ago following ignition failure, Delivered next day for £58 (complete distributor). Took about 10 mins to set up and get running perfect, to be fair, best £58 spent on the car so far.
Kev
1stpop
PostPosted: Sat Jun 14, 2014 9:45 pm    Post subject: Reply with quote
cheers - what car is it - just out of interest?
PostPosted: Sat Jun 14, 2014 9:46 pm    Post subject: Reply with quote
Mine? singer vogue mk3
Kev
