Vacuum Bleeder
jddevel
PostPosted: Sun Aug 10, 2014 10:24 pm    Post subject: Vacuum Bleeder Reply with quote
Anyone have experience of these? In particular their ability to assist in clearing out a silicone fluid to replace with Dot4
PostPosted: Mon Aug 11, 2014 8:22 am    Post subject: Reply with quote
I have an easibleed which is a great bit of kit.
I have done fluid flush and change loads of times using it and makes the job possible even if there is no additional assistance available.
Kev
D4B
PostPosted: Mon Aug 11, 2014 9:49 am    Post subject: Reply with quote
Kev
Agreed, as long as you can find a cap to fit your brake master resevoir
PostPosted: Mon Aug 11, 2014 10:20 am    Post subject: Reply with quote
Kev
If Gunsons dont do one then just get a spare cap and modify it
Kev
D4B
PostPosted: Mon Aug 11, 2014 10:49 am    Post subject: Reply with quote
kevin2306 wrote:
If Gunsons dont do one then just get a spare cap and modify itKev
Not so easy to modify and when you add 16 euros postage makes for an expensive cap....
http://www.cmsnl.com/honda-tn360k3-tn7-rh-drive-mph-type-ke-panel-van_model14941/capreservoir_46202567000/#.U-iRLmNeI6g
although I guesss it's just a case of grinding the ridge off the cap and drilling a hole.
jddevel
PostPosted: Mon Aug 11, 2014 11:27 am    Post subject: Vacuum bleeder Reply with quote
Thanks all for that. Its a Sealey bleeder and arriving today so obviously not seen the instructions. However can you please expand on the need for a master cylinder cap. The car in question is a `55 MGTF.
Regards Jan
D4B
PostPosted: Mon Aug 11, 2014 11:43 am    Post subject: Re: Vacuum bleeder Reply with quote
Regards Jan
watch this video from 1 minute 30 secs....
http://youtu.be/Lz8t6ZkVSQM
or you might find more info about the kit you have ordered here:
http://www.sealey.co.uk/PLPageBuilder.asp?x=0&y=0&productdescription=bleeder&pageindex=1&gotonode=DoProductSearch&method=mProductSearch&IndividualTypeID=&category=0&requiredresults=16
