What are those called?
Wooster
PostPosted: Tue Aug 05, 2014 8:54 am    Post subject: What are those called? Reply with quote
This should be an easy one for you chaps to answer. Those t-shaped tools vintage cars have for opening bonnets and boots and spare wheel covers etc. What are they called?
PostPosted: Tue Aug 05, 2014 8:55 am    Post subject: Reply with quote
Budget lock key?
PostPosted: Tue Aug 05, 2014 9:25 am    Post subject: Reply with quote
Vintage Square Key?
just ebayed it and found this:
http://www.ebay.co.uk/itm/VINTAGE-CAR-or-BUS-SQUARE-KEY-DOOR-BOOT-TRUNK-ROLLS-ROYCE-BENTLEY-MORE-/390886051641?pt=UK_Car_Parts_Vehicles_Automobila_ET&hash=item5b029fcf39
PostPosted: Tue Aug 05, 2014 9:28 am    Post subject: Reply with quote
Forget that ebay one, Woolies have it:
http://www.woolies-trim.co.uk/p-975-carriage-key.aspx
PostPosted: Tue Aug 05, 2014 9:33 am    Post subject: Reply with quote
Not always T shaped, mine a sort of L , just to confuse you Smile
Wooster
PostPosted: Tue Aug 05, 2014 10:25 am    Post subject: Reply with quote
Thanks everyone. Now I have to work out what size I need. It's for a pre-war Rover.
PostPosted: Tue Aug 05, 2014 11:04 am    Post subject: Reply with quote
Aren't they known as carriage keys, the railways used them from quite early on.
They were used to prevent passengers opening doors while the train was in motion, even as a kid although the railways had permanently fitted handles they were only on the outside of carriages, so that the window had to be dropped in order to open the door from inside.
PostPosted: Tue Aug 05, 2014 11:52 am    Post subject: Reply with quote
Sorry to go off the original topic, but Penmans post reminded me that my parents recently stayed in a beach front property at Pagham in Sussex, which was built from old railway carriages, presumably from the London to Brighton and South Coast Railway, as here is the bedroom door handle:
P3steve
PostPosted: Tue Aug 05, 2014 12:14 pm    Post subject: Reply with quote
I have a late 1940s Rover P3 and the T handle key on mine is used to open the spare wheel cover inside the boot lid and the square section on mine is tapered and I'm sure most of my tools are original there Rover marked and are the same as the earlier Rovers. Try contacting this chap he deals in pre 1950 Rover spares and dose have some original tools I believe http://www.thersr.co.uk/meteor-spares-ltd (usual disclaimer etc)
ps if you want I can measure and photograph mine if it would help
PostPosted: Tue Aug 05, 2014 1:14 pm    Post subject: Reply with quote
I suspect they are all tapered so that each one covers a number of different lock sizes.
PostPosted: Tue Aug 05, 2014 7:07 pm    Post subject: Reply with quote
They are properly called Carriage keys and were used on the railways. One is used for the spare wheel cover and under rear=seat tray on our Rover P2 16 - it is kept in the tool tray under the dashboard
Rover P2
Morris Mini Traveller Mk2
Wooster
PostPosted: Wed Aug 06, 2014 5:19 pm    Post subject: Reply with quote
Thank you everyone. I've ordered one from Woolies.
