Morris 8 S1 SU needle
Timstopp
PostPosted: Thu Aug 07, 2014 3:23 pm    Post subject: Morris 8 S1 SU needle Reply with quote
Hi, having taken my carb apart for an inspection, I have found it is fitted with an EK needle. Burlen specify a BD and I wondered if there was a reason for the EK needle ( maybe a common change?) or do I just have the wrong needle?
I tried Burlen for a replacement but they said not in stock for 8-9 weeks!
Would it be rude to ask if anyone has a spare they would sell me?
North Essex,UK - Morris 8 tourer 1936 - Jaguar x350
PostPosted: Thu Aug 07, 2014 3:34 pm    Post subject: Reply with quote
Always worth having a look on fleabay for odd SU needles, you could just strike lucky.
ka
PostPosted: Fri Aug 08, 2014 6:38 am    Post subject: Reply with quote
I found DB Carbs in the Old Cattle Market in Nottingham held a good stock.
But a question, different needles were fitted to differing markets destinations, i.e., hotter, colder etc. It may be yours just has an replacement needle. Is there a problem with it, does it run ok? maybe you are repairing something that isn't broken!
D & B Carburettor Specialists Ltd
Car Engine Tuning & Diagnostic Services (Workshop & Repair Centres) based in the Cattle Market Road area of Nottingham
Tel: 0115-986 4971
Address: Cattle Market, Cattle Market Road Nottingham Nottinghamshire NG2 3GY
View D & B Carburettor Specialists Ltd's profile
KA
Better three than four.
goneps
PostPosted: Fri Aug 08, 2014 6:55 am    Post subject: Reply with quote
EK is the standard needle for the Series E, so are you sure you have the right carburettor (presuming your engine is type UB 1934-38 Eight)?
Quite a few pre-E Eights have been converted to either a Series E motor (USHM) or the military ("tank") engine. If yours is one of these it will most likely have a Series E carb with 1 1/8" choke, as opposed to the 1" choke of the earlier cars' carbs.
Richard
