Plating in Vintage Rolls Royce
PostPosted: Mon Aug 18, 2014 1:52 pm    Post subject: Plating in Vintage Rolls Royce Reply with quote
I know this is for a specific make but could be of general interest and find an answer more readily here.
A friend in Australia asked:
Peter ,
I was wondering if you could ask on the forum if anyone these days knows about the original plating method for Rolls Royces in the 20s?
The fittings weren't electroplated, but had a shim of [ I think] Nickel silver -" german silver"] soldered on.
Cut neatly to fit and presumably shaped somehow for the curved surfaces.
I wonder if anyone still knows how to do it
I saw a group of RR Silver Ghosts at an international rally and all had been done with electroplating,..... and spray painted : >(
I wonder if this skill is at the cusp of extinction, or perhaps even gone
Regards,
Ed
Anyone know or have thoughts?
Thanks,
Ashley
PostPosted: Mon Aug 18, 2014 4:37 pm    Post subject: Reply with quote
I think everything R-R was dull nickel plated until about '52 when the switched to cadmium. All plating was done in house to their exacting standard and that includes chrome. Unlike any other British car, everything on a Rolls was unique to them. They didn't share a single switch or lock even.
SUs and Lucas stuff was made to their design on the later cars, so bear that in mind of you're considering one. It all costs a fortune and until 1985, they even made all their one nuts and bolts.
PostPosted: Mon Aug 18, 2014 4:56 pm    Post subject: Reply with quote
Thanks for your reply Ashley. Perhaps I shouldn't have used the word plating in the title. What Ed is looking for is information regarding a separate outer skin of nickel silver and not an electroplating process.
Have you ever come across this?
Thanks,
V8 Nutter
PostPosted: Mon Aug 18, 2014 7:42 pm    Post subject: Reply with quote
I have no idea about Rolls Royce plating, but I am pretty sure Ashley is wrong when he says RR made everything. I believe they have used the following G.M. designed if not manufactured components, automatic transmissions, power steering, A.C., hydraulic tappets, electric window lifts, and electric seat mechanisms.
The story goes when R.R. first started using Hydra matic transmissions they made them under licence, they tightened the tolerances and clearances and the transmissions didn't work. After that they bought them direct from Cadillac. I have also heard of restorers fitting Cadillac hydraulic tappets, because they are so much cheaper.
Ashley
PostPosted: Mon Aug 18, 2014 9:05 pm    Post subject: Reply with quote
Not until the Shadow did they use GM stuff or anything from outsiders except the hydramatic gearbox. I'm pretty sure even the Shadow had R-R seat mechs and window winders and that most of the aircon was theirs too. Only the compressor was bought it.
They only bought the first 25 hydramatics from GM then they made their own under licence. They didn't like the finish on the clutch plates so they improved them only to have jerky gear changes, so from then on they continued to make them better and then put them in a modified washing machine with abrasive bricks to rough up the surface.
They were bonkers and of you're interested there's a book called Kidnap The Flying Lady that explains it all. I did have a Shadow and a Spirit in the day and years ago an S1 Continental, but I think,their last good car was the R Type. The rest were over complicated, not especially reliable and ludicrously expensive to run. Www.kda132.com
PostPosted: Tue Aug 19, 2014 11:59 am    Post subject: Reply with quote
Peter,
I have a feeling that Ed's original enquiry may be related to pre-war Rolls Royce plating. I found this on Youtube https://www.youtube.com/watch?v=cjnZGQZAoHU which seems to relate to Rolls before BMW took them over.
On the gearbox question, I'm pretty sure that Rolls built their own Hydramatics under licence. I worked on Rolls for a short time in 1964 doing all the crappy jobs like removing the auto boxes from S2 Clouds. The torque converter was bolted to the flywheel/adapter plate with about 20 5/16 nuts. The Cadillac equivalent had 4 bolts doing the same job. The S1 Cloud used the same gearbox without problem but they were only 6 cylinder 4 1/2 litre ??? As soon as they went to the 6 1/4 litre V8s the transmission just wasn't up to the torque and would burn out after 3-4 years which were still covered by the Rolls warranty.
Art
Ashley
PostPosted: Tue Aug 19, 2014 1:08 pm    Post subject: Reply with quote
You're right Art, a friend of mine used to say that a good engineer was the chap who could design something for a pound when everyone else was spending a fiver and R-R twenty!
There's a hotted up A35 in the workshop today having a supercharger fitted and a complete front suspension/steering overhaul. I think the bill for everything was about £300 and for similar and larger on a Cloud it would be over £3000.
People marvel at the complexity and beauty of R-R mechanicals, but they weren't particularly reliable, very few even now know how to work on them correctly and they cost an absolute fortune to restore or repair. And then they aren't worth enough to justify the expense.
IMO R-R's expertise is and always was aero engines. They made the best of two wars and they still make the best now.
PostPosted: Tue Aug 19, 2014 3:30 pm    Post subject: Reply with quote
47Jag wrote:
Peter,
Art
Indeed it is Art. He asks about: "the original plating method for Rolls Royces in the 20s? "
Ashley
PostPosted: Tue Aug 19, 2014 7:00 pm    Post subject: Reply with quote
As I said, everything was dull-nickelled by R-R, but external fittings were provided by the coach builders.
goneps
PostPosted: Wed Aug 20, 2014 12:26 am    Post subject: Reply with quote
Hmm... Even there the reputation greatly exceeds the truth. The legendary Merlin, for instance, was a triumph of development over design. The respected author Bill Gunston summed it up thus: "Seldom has an engine proved so disappointing for so long". Early examples routinely failed type tests, and several redesigns were necessary to achieve a serviceable motor. The X-24 Vulture for the Manchester was a catastrophe, regular engine fires and big-end failures scarcely endearing it to aircrews who had to contend with quite enough life-threatening hazards without the worry of fragile engines. The RB211 gas turbine brought R-R to its knees before extensive redesign finally snatched victory from the jaws of defeat. And wasn't it a Trent turbo-fan on a Qantas A380 that blew up so dramatically a couple of years ago?
All of which is not to deny that R-R have produced many marvellous engines—only that we should not allow the fable to overwhelm the reality.
SpiggyTopes
PostPosted: Wed Aug 20, 2014 11:10 am    Post subject: Reply with quote
Thanks for bringing us back down to earth.
It is good to be reminded of these things and not get carried away too much.
PostPosted: Thu Aug 21, 2014 7:58 am    Post subject: Reply with quote
IMHO Rolls-Royce can get away with murder when they can build an engine that sounds like the Merlin under full power. That whistling howl! Wow! Fabulous! Raises the goose bumps on my skin and the hairs on the back of my neck!
Keith
Ashley
PostPosted: Thu Aug 21, 2014 9:23 am    Post subject: Reply with quote
And all aero engine companies, car companies, all companies make mistakes and pursue flawed ideas, it was just that R-R did better and still do the best.
They went bust in seventy one trying to build a technically very advanced engine for the Tristar and if the Government hadn't bailed them out and they hadn't sorted it out they wouldn't be one of the largest and best now and I believe the only company to make an engine suitable for the A380.
Cars were different, IMO they should have accepted that Model T Fords gave as good an account of themselves as Silver Ghosts in the deserts of the Middle East in World War One and learnt from the genius of our Henry.
alanb
PostPosted: Thu Aug 21, 2014 9:40 am    Post subject: Reply with quote
I can remember an old saying, that it wasn't what went into a RR that made it expensive it was what they rejected.?
old tourer
Morris 8 two seater
Ashley
PostPosted: Thu Aug 21, 2014 4:38 pm    Post subject: Reply with quote
Would you believe that all ball bearings had to have double thickness hardening and that they'd dismantle them, put each ball on top of a column of air and using a powerful beam of light, project its outline onto a huge screen. Any imperfections meant the balls were rejected. They'd assemble the remainder and use them and reject the rest.
They designed all their own SUs and had them made under supervision at SU and it was the same with dynamos and starter motors.
This was all up towards the end of the Cloud. The Shadow was the first to use bought in power steering boxes etc.
