Carver Heater Help
Fluffle-Valve
PostPosted: Thu Aug 14, 2014 4:48 pm    Post subject: Carver Heater Help Reply with quote
All of a sudden while out the other weekend in my Castleton Roberta, when I switch my heater on, the green light doesn't come on and the two lights on the fridge comes on instead. It does the same when I turn on the hot-water heater.
At the moment, because of this, I have no hot water and no heating. Neither will switch on except for the lights on the fridge.
Anyone got any ideas on where to start looking? Confused
This is the switch for the heater.
Flick this down and two lights on the fridge come on.
The two lights on the fridge.
ajlelectronics
PostPosted: Thu Aug 14, 2014 10:02 pm    Post subject: Reply with quote
You have a fault with an earth. Both devices probably share an earth point which has gon open circuit. Therefore the heater is trying to earth through the 'fridge.
Evans Waterless Coolants
Sat TV / Aerial systems etc: http://www.ajlelectronics.co.uk
Fluffle-Valve
PostPosted: Thu Aug 14, 2014 10:17 pm    Post subject: Reply with quote
So I'm guessing I need to trace the earth wire starting at the battery?
ajlelectronics
PostPosted: Thu Aug 14, 2014 10:51 pm    Post subject: Reply with quote
Trace the earth from each appliance and see where they coincide first.
Fluffle-Valve
PostPosted: Fri Aug 15, 2014 8:17 pm    Post subject: Reply with quote
Going to have a look tomorrow afternoon.
Just haven't had the time to do anything just lately.
Fluffle-Valve
PostPosted: Fri Sep 12, 2014 7:30 pm    Post subject: Reply with quote
I have had a look now and found a fuse had blown on the heater wiring. Heater now works but the Hot water is still not working. Getting plenty of spark, but no gas to fire up. I'm suspecting its the gas valve on the hot water burner not working. I'm not going to pull it all apart till the end of September when I stop with the steam rallies, as it all looks very rusty and a bit fragile. I'll have a proper look in a week or two.
