traction39
Posted: Mon Oct 06, 2014 9:51 am Post subject: Tachometer and magneto |
Experts,
Is it possible to hook up a BTH magneto with a tachometer? (Riley 9)
If so, how?
I know how to connect a tacho to a distributor/coil engine but unsure whether this is possible with a magneto.
The usual pick up off the inlet cam is unavailable without major changes.
Anyone have the knowledge?
Alistair |
Old Wrench
Posted: Mon Oct 06, 2014 10:44 am Post subject: |
An electronic tachometer is simply a pulse counter, plus diode to rectify the AC current and uses a large scale deflection meter.
You would have to detect "pulses" from the low tension side of the magneto points: rectify and then "count".
Alternatively, you could detect pulses from a plug lead.
Most cars of that era used cable-driven chronometric mechanical tachometers, via a drive gear take off normally from the camshaft.
Later versions (e.g. Jaguar sports and saloons) used a small electrical generator driven from one camshaft end and again a standard moving coil meter to indicate approximate RPM.
A case of experiment, trial and terror ( ) and work on first electronics principles.
Many light aircraft still use magnetos, so this could be a point of research.
Some references here may assist:
http://www.donzig.com/tachometers.html
http://www.bowersflybaby.com/tech/tach.html
http://www.eng-tips.com/viewthread.cfm?qid=320604 |
Old Wrench
